Results 1 to 12 of 12
    Jul 2019
    I bought a second hand car and planning to change the engine oil. According to the manual and last PMS in the case, the oil used is 10W-30. This morning, we went to two Shell gas stations to inquire. They said Shell does not have a 10W-30 sa Pinas. Ang meron lang is 5W-40. I do not know if I should continue my search or try na yan. Let me know your thoughts. Salamat.
    Apr 2014
    Should be fine with 5w-40.
    As long as nasa range of accepted oil sya based sa manual for the engine.
    Aug 2009
    Quote Originally Posted by WersUrShock View Post
    Meron 10w-30 ang Shell. Helix HX7 blue bottle..
    either viscosity will work. the 10w30 is better in terms of fuel consumption. with rising fuel cost and idling so much coz of traffic, iwould recommend the 10w30.
    Jul 2019
    Quote Originally Posted by Sleepcare View Post
    We went to two gasoline stations. Wala daw. Ang 10W-30 for diesel lang. Anyway, will continue looking. Thank you.
    Jun 2005
    Wala naman masama sa w-40 na oil. Gamitin mo lang ano available. Oil changes is not rocket science
    Sent from my MI MAX 2 using Tapatalk
    Dec 2009
    10W30 will save you more fuel..that will help the environment
    May 2011
    If you are particular on using 10w-30, try lazada. they have quite some choices in that viscosity range. hth
    Jan 2009
    Quote Originally Posted by mina_nuka View Post
    GF-6(A and B) / API SP won't be available until around the middle of next year.
    Feb 2007
    Unioil carries Idemitsu 10w30 oil
    If daily driven, how about 5w30? Oils with this viscosity are mostly fully synthetic unless you don’t want to use fully synthetic.
10W-30 or 5W-40?
