Results 1 to 13 of 13
    Dec 2008
    Hello mga sir! I would like to seek for your expert advise regarding on my problem I've experience on my Nissan GSX and I'm just in car. As I start the engine, the idle rpm abnormally drops down near zero then after approximately 3 secs it goes up to its normal idle rpm of 650 and I already encountered this twice. Ano kaya problema nito? Actually, I'm planning to bring it to the CASA since under warranty pa naman ito. Gusto ko lang po sana pagpunta ko doon alam ko na po ang sasabihin ko. TIA!
    May 2007
    [quote=Yenfico;1190272]Hello mga sir! I would like to seek for your expert advise regarding on my problem I've experience on my Nissan GSX and I'm just in car. As I start the engine, the idle rpm abnormally drops down near zero then after approximately 3 secs it goes up to its normal idle rpm of 650 and I already encountered this twice. Ano kaya problema nito? Actually, I'm planning to bring it to the CASA since under warranty pa naman ito. Gusto ko lang po sana pagpunta ko doon alam ko na po ang sasabihin ko. TIA! [/quote
    If still in warranty it is your best interest to bring the car to dealer to fix that problem.
    Aug 2005
    Under warranty pa po pala, so eto po sabihin mo:
    Nov 2003
    could be the servo or a dirty throttle. shouldn't be that hard to fix on a relatively new car.
    pa check mo yug air cleaner mo ... or baka may hose lang natangal sa may throttle
    Jan 2009
    Is the engine cold or warm?
Idle RPM abnormal drop
