Page 1 of 2 12 LastLast
Results 1 to 10 of 12
    Dec 2010
    mga fellow drivers..
    ask ko lang po anu po maganda 1/4 ng tank ko ang refil ko o 1/2 nito
    kasi po short distance lang po tinatakbo ko about 1km balikan tapos 3x a week ko pa gamitin yung auto anu mas matipid sa fuel consumption
    kasi short distance lang eh .. salamt sa mga mag reply !!!!
    Quote Originally Posted by genowel View Post
    Personally I prefer to refill at 1/4 left in the tank. But the difference between refueling at 1/4 & 1/2 tank levels is negligible, assuming the gasoline station is along your normal route.
    Feb 2009
    if you leave your fuel tank always low, the air that enters the tank contains moisture and in time condense and accumulate and settle at the bottom of your tank. this will consequently cause rough engine idle and occasional sputtering. true, a low fuel level fuel tank is lighter and therefore conserve a little bit of fuel. if the fuel in the tank sits there for months at a time, the fuel becomes stale resulting in poor engine performance and tend to develop gum and varnish all throughout the fuel system. if the fuel will have to sit there for an extended period of time, it is recommended you add fuel stabilizer that's readily available at hardware stores.
    Dec 2010
    "negligible" pls expand this word ...
    1 Km balikan? Gusto mo makatipid? Magbike ka na lang. Lapit lang nung 1 Km. Tipid na sa gas, bawas polusyon pa.
    May 2009
    +1...............less fuel, more space for moisture esp. on cold weather...
    Dec 2007
    Quote Originally Posted by gaspanic View Post
    Pwede nang lakarin yun, 500m lang one-way (kasi 1km balikan daw, e). :D
    [size=1]7/3,893(3,870 + 23)[/size]
    Dec 2010
    Quote Originally Posted by woohoo View Post
    hindi po pwede may kasama po akong senior eh...
    so...
    anu po ba ang the best ... ? solution
    totoo po ba talga yung fuel stabilaizer ??
    don't use any additive. If I were you refill at half tank. And take drive your car longer on the weekends to let it breathe.
    boy would I love to be in this situation - ok nga magbike nalang
    I would load ideally at half tank but most of the time between 1/4 and 1/2 especially with the current situation (starting from the closed pipeling up to the problems in Libya)
    Never go near empty is a must
1/4 of gastank or 1/2 of gastank
