Results 1 to 9 of 9
- Feb 2006
- 771
October 21st, 2007 02:16 PM #1mga sir,
ask ko lang po kung ano yung wire size ng mga ginagamit na wirings ng kotse?
parepareho lng po b yun sa mga headlights, fans , at other wirings ng electrical systems ng buong kotse?
balak ko po kasi irewire paunti unti yung mga wires nung ride ko kung minsan na sipagin ako hehehe
salamt po
October 22nd, 2007 02:29 AM #2
Yes, with exemption of ignition wire ,batt. cable, fuses and relay wire.
- Feb 2006
- 771
October 22nd, 2007 02:21 PM #3salamat po sir,
and pwede po ba malaman yung wire size nya?
i mean yung AWG size o. nya?para pag bili ko hardware /electrical shop yun sasabihin ko?
October 22nd, 2007 08:11 PM #4
for what type of car sir? i think its gauge 14 get the original japan or branded wires para di substandard ang sukat ng coppers
October 22nd, 2007 08:39 PM #5
- Feb 2006
- 771
October 24th, 2007 05:33 PM #6thanx for the input sir toolightz
bale gauge 14 po pala yun?tsek ko po sa hardware malpit sa min kung meron sila mga iba iba brand ng wire,btw any brand you can recommend sir?tsaka ano pa ba yun sir stranded , straight?iisa lang nama yat yun klase di po ba?mostly yung wires siguro ng ilaw kasi puro tape na e kaya balak ko irewire para maging malinis tingnan di ba?
* Sir VtEC
ano po ba mga klase ng wire to sab nyo?local hardware electrical shop kay meron nito?any idea kung saan makakabili nito?by meters din po bentahan nito?
salamat po sa input mga sir
- Aug 2006
- 21
October 24th, 2007 06:07 PM #7di ko lang sure kung applicable to sa kotse but maybe you can use THWN na wire. di brand yung THWN ha? code yun para sa applications ng wire. they are rated for hi-temp 90 degrees celsius (H) and wet applications (W). kung gusto mo gawin mo nang #12 AWG, yun nga lang kakapal yung cable tsaka mas magastos per meter, but safety wise, on my own opinion, mas maganda sya. rated for 20 amps ang #12 AWG while 15 amps ang #14 AWG. so talagang fuse muna ang masisira bago yung wire (which is supposedly dapat, pero minsan, due to deterioration ng wire, wire na yung nasusunog)
October 24th, 2007 07:25 PM #8
masmaganda gamitin sa ay ang stranded wire ito yung maraming wire na maliliit sa loob, masmalaki ang rating nito compared sa wire with the same diameter na malalaki ang wire sa loob. kasi ang current nag flow lang sa outer part ng conductor aya masmalaki ang surface area masmaganda "skin effect" tawag dito.
October 24th, 2007 08:59 PM #9
