View Poll Results: When replacing your batt do you wait for it to die or buy a new one every X years?
Voters
62. You may not vote on this poll
  • Wait for it to die
    43 69.35%
  • Buy batt every X years.
    19 30.65%
Results 1 to 20 of 68
    Sep 2005
    Please post your car's model and setup and the number of years you wait, for you to replace your old batt.
    May 2005
    waited for it to die. usually ayaw na mag start sa umaga
    Mar 2004
    I usually wait for the car to show signs of the battery dying. In my car, City'03, the power window's single pinch button on the driver side will stop working. Also, when starting the car, there's a telltale "wrong" sound when the engine revs before starting. Normally, it's "WEH-WEH-Broom!" When the battery is close to dying, my car starts up, "WEHHHHH-WEH-Broom!"
    Heheheh....
    When any of the two happens, I usually have 1-2 days to replace the battery before it goes flat dead.
    Aug 2007
    happen to my honda crv A/T dec.2002 nabili, then nung pms checkup year 2005, time na pipikupin ko na from casa ayaw start sakto me mga service crew dun kaya no prob. la kase akong sign na nakita na mahina na batt. iniwan ko kase sa casa for 3 days ata (change oil, undercoating, hydrophilic and engine wash). . . .di ko na paabutin 3 years batt ko : )
    Dec 2003
    i always wait for the battery to show signs of weakening before replacing, pero never yung patay na talaga..delikado yun tirikan pa ako sa malayong lugar
    Jun 2005
    Quote Originally Posted by BlueBimmer View Post
    I do this too!
    :work: [SIZE="1"]3166[/SIZE]
    Same here! Yung Civic 2002 ko dati about 4 years on the dot. Pag normal start kasi, 1 quick click lang siya. Pag hindi tumuloy, malapit na siya but don't expect it to happen in less than 3.5 years unless may ibang problema.
    Yung FXT ko now, hindi ko pa alam.
    Oct 2004
    I wait for it to die...
    My current one (Motolite Gold 3SM MF) will turn 4 years old on October...
    So far, malakas pa rin, pero binuksan ko na yung seals nya for top-up and checking of specific gravity of the solution (mula last year)... wala na rin namang warranty eh - and I might be able to still prolong its life by always checking the solution.
    Jun 2006
    wait for it to die... kailangan masulit para hindi sayang...
    usually malalaman mo pag malapit na matigok during cold start, preferably early in the morning...
    to prolonge the life always check the battery fluid, except for those who have or using maintenance free...
    one more thing, over charging shortened the life of the battery. kapag lumobo ang battery over charged iyun...
    May 2005
    Quote Originally Posted by froshie1 View Post
    i buy a new battery on the day the warranty expires. my ride is 93 A/T model with stock setup.
    Last edited by magnus; September 4th, 2007 at 03:24 PM. Reason: added some more words.
    Aug 2007
    basta may signsand symptoms na nagpapalit na ko. '99 HONDA SIR.
    to the OP:
    you can always have the battery and the vehicle's electricals checked. my trusty battery dealer does it for free, testing for the battery's nominal output, charge capacity, and what-not. it then gives out a reading, giving you an idea just how 'healthy' the battery is.
    or pwede rin 'pakiramdaman'. fresh batteries crank and start any vehicle almost instantaneously, assuming there are no other problems. batteries that have been in use longer take more time to crank and start.
    Jul 2006
    ako last check sa battery.
    pinalitan na lang ng battery solution.
    Aug 2005
    Quote Originally Posted by chr1smj_15 View Post
    True po yan,may signs naman po when you need to look for replacement na.But if you have plenty moolah,every 1 year pwede na kayo magpalit.
    i wait for it to die out
    speaking of changing batteries
    san ba mura bumili? i checked around evangelista today and 3sm motolife excel cost in the upper 5K to 6K
    Jun 2006
    Quote Originally Posted by Chip View Post
    Try Motolite enduro its their lower end battery. 1 year warranty, just bought one for P3450, sa Lipa City nga lang.
    Ok din Outlast, per their website 3SM or N70 prices:
    Premium 1 year warranty 4,300, pag di tubig 1 year warranty P3,600
    Super preimum 15 month warranty P4,000
    Super preimum 20 months warranty P5,400
    Exceed 24 months warranty P6,000
    BTW, san mura bumili ng 8D or N200? I need 2 eh ang mahal ng Motolite and Outlast. Pinaka murang canvass ko ay P9,000 each 9 months warranty lang. Ok kaya ang ibang brands? Tatagal kaya?
    pag mahina medyo mahina na, trade in na para sa bago.
    wait for it to die AFTER you or your mechanic (w/ electrical know-how) have checked terminals, alternator charging &/or starter (for starting problems), ignition coil, high tension wires, fuses, etc.
    a lot of alternator defects are mistaken to be caused by weak or dead battery.
When replacing your battery do you wait for it to die or buy a new one every X years?
