Results 1 to 10 of 10
- Aug 2009
- 12
November 6th, 2009 02:43 AM #1nissan sentra, 1994 model,manual transmission, ayaw mag start
sir newbie lang, ayaw magstart ng oto ko not unless itulak, pag insistart walang redondo, umiikot lang ang fan pag inistart, pinacheck ko sa mechanic sa shell, tinest yung baterya malakas naman karga, malaks naman mga lights at busina, sabi ng mechanic terminal lang daw ng battery, nastart ko pa pag alis ko sa shell pero kanina bago ko pumasok ayaw na naman mag start, napalitan na namin terminal ng battery, same prob pa din, kailangan itulak para magstart, ano kaya problem?
thanks in advance
November 6th, 2009 06:51 AM #2
Kung malakas ang battery . Pa check mo spark plug baka palitin na kaya mahirap mag start at iyong engine timing kung nasa ayos ayon sa specification ng makina.
- Sep 2009
- 4
November 6th, 2009 07:33 AM #4
newbie,
if the car starts when pushed, the engine must be doing okay. but if you try to normally start it and it does not crank, check the starting system. you already confirmed the battery is okay, now start with the ignition switch, then the clutch inhibitor switch, the starter relay, starter solenoid and finally the starter motor for worn out carbon brushes. this might be overwhelming to you. take this to a competent technician with that sequence of checks.
jick
November 6th, 2009 09:11 AM #5
- Aug 2009
- 12
November 6th, 2009 11:21 AM #6mga sir salamat sa mga tips, kakadala ko lang sa mechanic yung carbon brush ang problem kaso wala ko mabilan ng same carbon brushes ng sa starter ko
November 6th, 2009 02:12 PM #7
lextripp,
you have a hitachi starter motor. any hitachi starter motor share the same brush holder assembly including that of chrysler jeep. it is easier to replace the brush and holder assembly than trying to solder the brushes to the holder plate. the liquid solder(while the solder is hot) tends to get wicked to the wires (capillary action) thus your brush wires will not flex because of the hardened solder.
jick
- Oct 2009
- 12
November 6th, 2009 10:08 PM #8Start troubleshuuting from the Igniton switch, Dapat may B+ sa relay coil/terminal ng Solinoid switch. Kung walang clicking sound habang ini-istart, malamang ay walang B+. Kung may klick pero di umikot ang engine, the trouble is with the starter: maaring solinoid switch, carbon brush or rotor coil or stator coils... or just a lose connection on the starter B+.. yung malaking wire,,,
Bro., nothing to do with the timing or Spark Plugs, umandar naman kasi... pag tulak...
- Aug 2009
- 12
November 10th, 2009 08:25 AM #10problem fixed, the carbon brush was replaced, now its working fine, thank you guys
Denali Lights, Dial Dim, & Soundbomb Review—Is It Worth The Premium? | Behind A Desk MotoDeal
Auxiliary Driving|Fog Lamps
