Page 1 of 2 12 LastLast
Results 1 to 20 of 31
    Nov 2006
    Mga Bro hingi lang po ng inyong advice kung ano gagawin in a situation wherein kapag na battery drain out ka na talaga na mismong stereo ayaw na mag activate at wla na talaga pag asa mag start yung oto..
    Jul 2005
    for carburated cars pwede tulak or (kadyo) it will start for injected maybe you can call a friend for help ( jumper cables )
    Nov 2006
    kc kahapon po im on my way to san pablo for a meeting tapos along the way lapit na ko sa highway exit bglang ayaw na magstart ng oto ko which is a 2004 revo vx240d (diesel).. ayaw pa rin nya magstart kahit sa kadyo.. does it means na hndi carbureted engine ko?.. di ko po alam yung jumper cables? yun ba yung sinasabi ni lang series? o ishoshort?.. i feel so dumb kahapon..
    Thanks sa reply..
    Jun 2006
    Quote Originally Posted by 3sgTe View Post
    Thanks sa reply..
    Your Revo is a diesel and diesels don't have carburators. I am assuming your Revo has a manual transmission. Correct ba? You should be able to push start it. Don't know why it did not work. If you will use jumper cables, you need good quality ones for diesel engines. Higher ampere capacity. Check mo na lang manual mo for correct procedure. But its basically + to + and - to ground. And make sure that the car with the good battery is reved up before starting the dead car.
    Jun 2004
    Teka, clarify ko lang, did the engine die and fail to start while you were already driving? or paalis ka pa lang ayaw na mag start?
    Nov 2006
    yep.. it did not work sa tulak maybe im dumb also with that.. db pg tulak kapag medyo metulin na takbo start the engine in primera we even tried 2nd gear... no response.. mga ilang years po ba buhay ng battery the one i got here is the oriental turbo./.,
    Thanks talaga sa mga reply and advices!..
    Nov 2006
    i stopped over to wait for my girlfriend at their house then nung pgswitch ko sa keys waiting for the ignition coil to fade nagflufluctuate yung gauge lights ko pati stereo.. then when i started the engne it fails.. hanggang ilang beses ayaw pa rin..
    Thanks sa reply..
    Bro muntik pa tayong magkasabay, papunta din akong San Pablo kahapon for a meeting with our highschool classmates dyan sa san gabriel.
    Feb 2007
    HERE MY ADVICE TO START YOUR ENGINE WITH JUMP LEADS...
    1. Connect one end of the red jump lead to the positive terminal of the other car's battery. (colored red or marked with a P or a+ sign).
    2. Connect the other end of the red lead to the positive terminal of the discharged battery.
    3. Connect one end of the black lead to the negative terminal of the other battery. (colored Black or marked with an N or a- sign)
    4. Connect the other end of the black lead to the cylinder block or some other place where it will be in contact with the negative terminal of the discharged battery.
    *NOTE: BATTERY OF THE OTHER CAR SHOULD BE AT THE SAME VOLTAGE.
    Nov 2006
    Quote Originally Posted by jezreel View Post
    hehe.. oonga.. sayang natulungan mo sana ako.. ehehe and see my dumbness...
    Tulak lang =)
    Jun 2006
    if it happeneds late in the evening call your family member/relatives or friend who has a car to assist you, and ask him to bring a pair of jump leads... remember to connect them in order (good battery to bad battery; live (+) to earth (-) preferable if the earth is connected to the engine block or a chassis member...
    if your a member of any automotive club or association like wheelers or AAP just call them up and they will provide assistance to you...
    and if you have enough dough, just call up motolite, they can deliver a new set of battery to you wherever you are...
    Quote Originally Posted by chuaed View Post
    NO, this is wrong. (+) to (-) results in a shorted battery which can lead to explosion of the battery (and acid burns on your face!)
    the right jumper cable connections are (+) of good battery to (+) of discharged battery, and (-) of good battery to ground point of car with discharged battery, then start the car with the good battery, rev up to around 2000 rpm, then start the car with the dead battery.
    kung diesel with manual tranny yan then you don't even need to use jumper cables as you can push-start it. put the gear in 2nd or 3rd (easier on 3rd than on 2nd, very hard to do on 1st gear), step on the clutch fully, have someone push the vehicle then release the clutch when the speed is high enough. be sure to be ready to pump the accelerator when the engine starts.
    check your alternator, baka sira na alternator mo kaya na-discharge ang battery. check also your elecrical connections baka grounded.
    another advice, since your ride is a diesel, it will be a good idea to have a can of starting fluid in your tool box. kung wala ka makita na starting fluid sa auto supply then a can of wd40 will do. when you get stalled due to a weak battery, open the air filter housing, remove the air filter and spray some starting fluid/wd40 into the intake manifold. (note: if the engine has a turbocharger find a plug after the turbo that you can open and spray the starting fluid direct to the intake manifold.) install back the filter before you try to jump start/push start the engine. it is easier to start an engine with a weak battery this way since the starting fluid does not need much compression to fire up the engine. do not use too much starting fluid as too much can damage the intake valves. just press the spray button on the aerosol can for 3-4 seconds and that will be enough to rev the engine to start.
    meron yata ako nakita sa ace hardware last time. di lang ako bumili at gasoline naman car ko.
  15. #15
    be careful kayo sa pag jumpstart ng EFI cars...baka ma-overload ang ECU ng lakas ng kuryente.
    and kung hihingi kayu ng jumpstart, dapat buhay ang mahina ng sasakyan.
    nga pala, di pwede kadyutin ang matic, (carb man or EFI/diesel) connected ang starter sa P at N lang.
    Nov 2006
    Thanks for the advices and tips!... also for the replies...
    Jul 2006
    For diesels that have glow plugs, starting fluid (known as ether) is NOT recommended. This causes the increased compression to push the weakest link, which could mean the glow plugs themselves. Worst case scenario is the glow plugs will explode due to the higher compression. Since it is also a diesel chances are the battery may be bigger with more CCA (cold cranking amps). This means it can deliver more current to the starter to overcome the high compression most diesels have. The problem is when you have a booster car with a gasoline engine, the battery is most often not suited to crank the diesel since the diesel requires a lot more CCA than the gas car battery. Plus, thicker gauge jumper leads are required to get the current across and avoid a large voltage drop. The longer the cable, the higher the voltage drop. But the longer the cable, the easier it is to connect the two batteries. Just make sure not to let the cars come in contact with each other. 6 gauge wire should be good here, 4 is better, especially with thick insulation and protected clamps (preventing accidental contact of the clamps).
    Goodluck na lang at sana hindi ka ma-tow kaagad. Have your pepperspray ready in case they board your car without your consent.
    Share ko na din nagyari sa elantra ng boss ko na ayaw mag start, nung pinuntahan namin may crack yung clamps ng battery niya, hindi masyado halata kaya better check all your electrical connections sa battery and alternator maski 2004 model pa yan he he yung kasama ko po dito ni rewire yung revo niya under warranty pa
    Nov 2006
    Goodluck na lang at sana hindi ka ma-tow kaagad. Have your pepperspray ready in case they board your car without your consent.[/quote]
    ive got a flashlight with a built in stun baton at my toolbox.. 300,000 volts...
    Jun 2006
    thats what i ment... susmaryosep mali english ko....
What to do in case of battery drain out in the middle of the road??
