Results 1 to 20 of 35
    Ano na ang kailangan palitan o pagawa kung mahina pa rin ang brakes
    kahit pinalitan na ang brake pads?
    Thanks.
    Aug 2004
    Is it weaker than before the pad change? ipa-bleed mo at ipa-adjust mo ang brakes ulit. Sometimes happens when I get new brake pads and they don't install them properly. Dapat free back-job yun.
    as per niky, mahina na ba dati yung brakes mo bago nagpalit ng pads, nagbabawas ba ng fluid, pedal goes to floor ba, spongy ba ang brake, excessive pedal effort, un-even brakes, etc,etc
    Yun din isip ko, may air yung brake lines.
    Either that or nagkaseal problem ang hydrovac or vacuum.
    Feb 2007
    Check your hydrovac and pa-bleed mo.
    Yep. Mahina na ang braking power even before its pads were changed. Pero kahit napalitan na ng bago the braking power only got very slightly stronger.
    Quote Originally Posted by usokpower View Post
    Thanks.
    are your brakes vacuum assisted?
    check mo brake shoe mo i assume front wheel drive ang kotse mo then its the drum brakes in the rear ang may problema
    Aug 2004
    The question is... what car is it? Some vehicles really have weak brakes.
    Quote Originally Posted by topgun View Post
    Its actually a 11 year old L200 I drive slower now because of this.
    Quote Originally Posted by t2erns View Post
    delikado 'to, possible sign of worn out rubber piston caps...
    having it said that it is 11 y/o, baka palitin na ang hydrovac mo...
    Thanks.
    napalitan/nalinisan din ba yung rear brake shoes and drums? properly adjusted ba?
WEak braking power despite new brake pads
