Osram Nightbreakers
or
Philips Xtreme Power bulbs.
both bulbs work well on the stock sockets and wires
Osram Nightbreakers
or
Easiest way is to upgrade your bulbs. Older bulbs lose efficiency over time. You can use +90 stock wattage bulbs like nightbreakers/XPs but these bulbs have short lifespan. Alternatively, you can upgrade your wires and then use higher wattage bulbs.
Currently, I am using Osram all-seasons with upgraded wiring/relays and it is far better that the stock wiring/bulb combo.
problem with the 90/100 bulbs...
they blacken the reflectors over time due to the heat
From what I have read, average is less than a year. That's why Osram has produced Nightbreaker Plus, claiming 50% longer life than the original nightbreaker.
This is all because of the filament design which produces more light for the same amount of energy being used (55/60w) in the expense of lifespan. High-wattage bulbs consume more energy to produce more light and have less compromise in terms of durability.
just want to share..
i use splitfire superyellow or artic yellow yung name niya sa package..
55w slang siya..pero maganda yung buga niya sa stock na headlight..
believe it or not i've been using it for 4 years now and its still works..
all stock wiring and sockets..
bought it for 800 for 1 pair.
HTH.
The bulbs have just the standard wattage. add that to the stock wirings and low usage you'll have long lasting bulbs.
