Results 1 to 10 of 25
- Apr 2010
- 38
April 23rd, 2010 03:30 PM #1Hi!.., bago lang po ako dito..,
can't find any threads which can help me..,
ayaw po kasi mawala nung warning light for open door.., even all the doors were already closed.,
what should i do?
- Apr 2010
- 46
April 23rd, 2010 06:58 PM #2my door jan n ndi nya n pupush ng maaus ung switch door..try mo close lhat den pag open mo ng isa i manual push mo ung switch,(isa-isa)pag nmatay n ung switch s alin mang door,un n ung ndi nya ma push ng maaus,gawin mo n lng lagyan mo ng goma ung tintamaan ng swicth s door...madali lng po yan sir...
May 10th, 2010 04:57 PM #3
Ganyan din problem ng vios ko. After mabaha, saka lumabas ang problem na yan. Hanggang ngayon di pa rin ma-solve. Almost everyday I remove the battery terminal to prevent it from being discharged.
Na-isolate ko naman yung problem. What I did is I set the dome lamp to turn-ON when the door is open. Tapos, inisa-isa ko pindutin yung mga door switch sa gilid. Yung isang door switch hindi nagre-respond everytime pini-press ko. I replaced it with a new door switch from the casa, wala pa rin!
Ang sabi, it's either the wires are grounded or the multiplex or fuse box underdash needs replacing. A brand new one costs P18,000. You won't find any surplus part.
Saan ko kaya pwede ipagawa to? Balitaan mo ko kung naayos na yung sayo ha. Thanks!
- Apr 2010
- 46
May 10th, 2010 11:34 PM #5
try adding a ground, baka nawala na yung contact. find the ground of the electrical to the door then use a wire then recta sa body pag nawala, kulang lang sa ground.
- Apr 2010
- 38
- Apr 2010
- 38
May 10th, 2010 11:49 PM #7sir, san po sa malolos?., natry ko na po ipress pero parang hindi sa sa switch ang prob.., I've pressed the switch on one door nung una ayaw.., then biglang nawala.., okei na sabi ko.., pagbukas ko nung door sa driver ayaw nanaman.., then i try pressing the door earlier pero ayaw na.., tapos ayon palipat lipat lang yung naglolokong side nang door..,
Haitzzz..,
- Apr 2010
- 38
May 10th, 2010 11:52 PM #8
- Apr 2010
- 38
May 10th, 2010 11:54 PM #9
May 11th, 2010 04:20 PM #10
Suzuki JIMNY [merged threads]
