oj88,
i totally understand your confusion. there are push/pull, reversible/reversible rotation aftermarket fans available out there. reversible simply means reversible. one of the reason why the blades are straight so it can be reversed and reduce drag when not rotating. this does not cause the life of the fan to prematurely wear out nor cause "electrical" problems as it was designed for that exact purpose. i have been installing them for years. i say again, for years. the last one i installed was on my 92 toyota previa as a helper push fan.it has been there for years until i decided to park my still serviceable toyota previa as a standby spare vehicle. the motors of this type is isolated meaning, it is grounded or only connected to the negative side through the wire or lead at the connector. i hope this clears one and all confusion pertaining this auxilliary fan question.
jick
a.s.e. certified master automobile technician
a.s.e. certified master heavy duty truck technician
international automobile technicians' network
Hi Jick,
I only mentioned that because the way things are here, Volts would probably be looking for pre-used aux fans. These used fans were most likely pulled out of old cars and therefore, OEM in nature and not the aftermarket kind you described. Being OEM, they're only designed for single polarity and airflow. At least, that's what I think.
