Results 1 to 13 of 13
    Apr 2005
    hi,
    What do you think should be the 3 most important gauges for a turbo car? I plan to install it sa A-pillar, so i can only have a maximum of 3 gauges. I actually have a built-in boost gauge sa instrument panel na, pero simple lang at walang psi readings, so I got a new one.
    What I currently have are (based on a friend's recommendation):
    - boost gauge
    - vacuum gauge
    - oil temp
    Recently kasi I read na very very important ang oil pressure gauge sa turbo car, so i got one as well. thing is, up to 3 nga lang dapat. so i have to drop one, what would it be, and where can i install it para nde naman sayang?
    Also, if you have other opinions on what gauge I should install aside from what I currently have please let me know as well. Please don't suggest EGT or Wideband 02 sensor at mejo malayo sa budget ko yun. hehe.
    Thanks!
    Quote Originally Posted by dirk_diggler View Post
    hi,
    - boost gauge
    - vacuum gauge
    - oil temp
    Thanks!
    -Boost/Vacuum gauge (yes, you don't need two separate gauges)
    -oil temp
    -oil pressure
    hi,
    - boost gauge
    - vacuum gauge
    - oil temp
    Thanks!
    -oil temp
    -oil pressure
    Example:
    Notice the needle is ZERO at the 10'o clock position. If it moves clockwise, it is boost pressure. If it moves counter clockwise from ZERO, it is vacuum pressure.
    Apr 2005
    thanks for the quick reply GH!
    engs din pala un friend ko na nagrecommend ng separate vacuum gauge. nadoble pa pala un bili ko. sayang naman.
    i guess pwede pa rin naman ito kabit sa other cars. oh well. is what you said true for all boost gauges? I currently have an auto gauge black face edition. nde ko pa kasi nakakabit so i don't know what it says yet.
    Thanks!
    Example:
    Thanks!
    No. There are gauges which displays boost pressure only.
    example:
    May 2009
    me ordered 4 gauges:
    1. turbo boost gage
    2. oil temperature gage (electrical)
    3. oil pressure gage (electrical)
    4. vacuum gage
    reason i plan to install a vacuum gage is that i'm toying with the idea of the vacuum gage serving as some sort of "filter minder" at the intake before the turbo. but that would still have to be finalized since i drive another gas engined car. I ordered the cheap CIRCUIT brands via my suking auto supply.
    Quote Originally Posted by miked View Post
    Waste of money. Plus you are making a complex build with more potential "fail" points. You would be better of changing air filters at regular intervals.
    Fail points? The vacuum gauge will have a (cheap) long long long plastic hose snaking from the gauge to the point where you will take vacuum. A pin hole leak will make the gauge useless and might even screw-up your air-fuel ratios.
    May 2009
    sir GH, any idea how much is that autometer boost gage?thanks
3 necessary gauges for turbo
