Results 1 to 10 of 10
- Mar 2016
- 12
March 30th, 2016 01:07 PM #1Will the speedometer read the same KPH/MPH on Automatic or Manual transmissions
March 30th, 2016 01:18 PM #2
There should be no difference. The speedo counts the number of times the wheels turn and doesn't care about the transmission type. Your speedo will be out of calibration if tires of a different diameter than the norm are used.
March 30th, 2016 01:26 PM #3
No difference. JohnM already explained it above.
- Mar 2016
- 12
March 30th, 2016 04:35 PM #4Thank you for the replies sirs. Btw, where do this cables/wirings of speedo attached? Nalilito kasi ako sa tinatawag nilang gearbox ba yun? May problema po kasi yung speedo namin, di pumapalo yung needle niya, ok naman speed sensor, sa connection sa dashboard na po kaya yung problema nito?
March 30th, 2016 04:56 PM #5
There is a cable that runs from your speedo to a gear inside the gearbox/transmission. Baka putol na.
More info here: How Speedometers Work | HowStuffWorksLast edited by JohnM; March 30th, 2016 at 05:00 PM.
- Mar 2016
- 12
March 31st, 2016 09:40 PM #6thank you po sir sa link. May alam po ba kayo na pwede mabilhan ng motor ng gear sensor? may ganoon daw po kasi sa banawe kaso masyado malayo. Ginagamit po siya pangtest ng speedometer gauge
April 1st, 2016 02:36 AM #7
Para sa anong car ba yang tinatanong mo bro?
Dalawang klase kasi yan... cable type na may gear sa dulo and meron din electronic speed sensor...
Sent via Tapatalk
- Mar 2016
- 12
April 1st, 2016 10:35 AM #8
yung ganito po na speed sensor
http://honda-tech.com/attachments/ac...electronic.jpg
April 1st, 2016 12:21 PM #9
- Mar 2016
- 12
April 3rd, 2016 01:10 PM #10Mga sir, mabalik lang po sa topic, bakit po pareho lang ang readings ng speedo nila kahit sa magkaibang transmission?
any articles/links po na nagpapatunay dito? Wala kasi ako mahanap po. Thankyou po
Yung extra AUX Fan is useful sa mga naka montero. Mag improve daw yung AC system since may extra...
