Results 1 to 4 of 4
    Aug 2008
    Please help! Hard starting in the morning. I found out that my glow plug were busted and replaced the glow plugs, When I tested the line, I found 14 volts electric current flows even engine is running! I would like to know were location of heater timer or control cutoff of my Isuzu Trooper 2003 model. Thanks
    After how many seconds did your heater function after you started your engine? Heater timer are design to stay on for a longer period when starting from a cold engine. When your heater light in your dashboard goes off it is an indication that you can now start your engine. It doesn't indicate that the heat plug is still supplied with current. Listen to the relay that clicks a few seconds after the engine has started.
    Aug 2008
    Quote Originally Posted by afrasay View Post
    Hi! My problem is the heater timer does not turns off, after the engine is running for more that 3 mins. I do follow the light indicator at the dashboard before starting the engine. And I observe that the dashboard light indicator turns off in a few seconds. There a lots of relays in the comparment. And I don't hear any click after engine running. I need to know the exact location of the timer switch or relay. Thanks.
    Not familiar with a trooper but you can look if it has a diagram aorund your kick panel, also in the engine bay.
Heater control cutoff
