Page 1 of 2 12 LastLast
Results 1 to 10 of 29
    Jul 2013
    Daytime running lamp (DRL, also daytime running light)
    Naisip ko lang...
    Since most entry level cars walang DRL...
    May special fuse ba ang top of the line cars na ginagamit for DRLs?
    Although yung mga mas bata nating members will mention na DRLs are LED lights... Nung early 90's most American cars' parking lights (and instrument panel) will light up once naka-on yung ignition ng car. Fast forward to the present time, ginawa lang LED yung lights... (Salamat Audi )
    So question ko is, kung entry level yung car without DRL... baka naman may pwede palitan sa fuse box nung car para gamitin nya yung parking lights as DRL...
    Although hindi kasing ganda kung parking lights ang mag-on... Para sa safety naman talaga ang DRL
    Naisip ko lang...
    sa truck ko may ginawang module si zix para sa drl. bale 50% (i think) lang ang output nung high beam kapag naka on iyong makina. And then deactivated siya kapag naka on na ang park lights and headlights. Although may option na always activated siya.
    siyempre correct wiring and all na siya (connected sa fuse and everything).
    baka pwede mo contact si zix para sa project mo.
    mas ok nga siya tingnan actually kasi parang oem. unlike doon sa fd2 ko na ginamitan ko ng led lights drl. although maganda din naman kinalabasan nun. si gary ng retrofit naman tumira nun
    Aug 2014
    Buy ka na lang ng ganito flush mount Drl sa Amazon. [emoji846]. images-20-202020-07-24t194304.299.jpg
    Sent from my SM-G965U using Tsikot Forums mobile app
    Naisip ko lang...
    a good auto electrician should be able to tap direct from the battery and have its own fuse to boot.
    also, look into your fusebox. there might be a spare tap there for "accessories".
    Jan 2008
    Naisip ko lang...
    No special fuse.. pero pwede ka mag gawa ng wiring to trigger the park lights using relays and diodes or install a dedicated drl tapped to your accessories line..
    Use a voltage sensor to turn the foglamps on only when the engine is running. Another relay will be wired in parallel to the existing fogLamp relay contacts.
    Jan 2009
    Ah, another DRL thread. Well let me tell you, I've been a believer that we don't need DRL in a tropical country. We don't have winter nor do we encounter fog on a regular basis (except maybe in one or two places), and for if we do encounter inclement weather or where there's limited visibility, you can simply turn on your low beams.
    DRL is just light pollution, IMO.
    Who needs DRL then? Motorcycles do. But as it is, in a sea of DRL from all vehicles on the road, you're likely to bury the motorcycles in all the "noise".
    BUT, if you're hell bent on putting a DRL and want it to behave like OEM, make it so that it can sense that you're neither in Park or Neutral and that the ignition is ON, before lighting up the DRL. Proper DRLs don't turn on with the engine. They only turn on when the vehicle is shifted into any of the drive gears.
    If that's difficult, another easy way to achieve similar results, is to sense the position of the handbrake. When the ignition is on and the handbrake is down, DRL should be on. In any other combination, the DRL should be off.
    Aug 2004
    This is a good idea. I had leds retrofitted in the headlights but I synched them to the park lights because the default setup is engine on = park light on.
    Sent from my SM-A605G using Tapatalk
    That's how it should be.
    But sadly even some OEMs did not wire it that way...
    now that i regularly bike the roads of our concrete jungle, i disagree w/ the idea that DRLs aren't needed in vehicles plying the roads of tropical Ph.
    i do understand that peeps here are reasoning w/ the mentality of an individual who is sitting comfortably behind a steering wheel, but if you were to think outside of the driver's seat, you guys will see how DRLs instantly enhances the visibility of a 2 or a 3 or even a 5 ton beast hurtling unpredictably through the streets full of random glare, irregular shadows, and blinding sheen - light pollution in other words.
    for a bicyclist, everything out there is happening w/ a millisecond delay. i've learned the hard way that a biker's senses are amped way more than a driver's sensory receptor at any given time and it can get confusing and tiring sifting through all those visual ( and auditory) cues. a DRL is not a cure all to those cycling baggage, but it sure does help in determining what's the correct action to take in a relative snap.
Daytime running lamp (DRL)
