Results 1 to 4 of 4
    Mar 2011
    Guys,
    Patulong naman po. Biglaan na lang po kasing ayaw gumana nung wiper, power window, headlights, signal light, and AC ko.
    Pina-check ko na po yung mga fuse sabi okay naman daw. Isang hinala nila yung fuse box na mismo ang sira.
    Baka may naka-experience na po sa inyo ng ganito.
    Salamat.
    Quote Originally Posted by unsec87 View Post
    Guys,
    Salamat.
    Fuse box is just a holder.
    Check the main terminal connection with the battery.
    If you step on the brake pedal, do the brake lights turn on?
    What is your ride?
    Guys,
    Salamat.
    see if there is something in common with all these dead gadgets.
    are their fuses all located in the same area?
    fuseboxes have been known to deform when hot.
    what is your car?
    some vehicles have fuses UNDER the engine bay fuse/relay box. since several things suddenly stopped then i suspect it is a master fuse that supplies power to all those things. tama na yung individual fuses are ok but the master fuse is not. usually nasa engine bay fuse/relay box yan or sa ilalim nun.
    read your car manual and check where this master fuse can be found.
Sudden no electrical connection/not working (wiper, power window, headlights, signal light, and AC)
