Results 1 to 11 of 11
    Apr 2010
    Good day mga sirs. Need help regarding our 89 corolla 4af engine. Biglang nawala ang park lights at gauge cluster lights. May sidemarker sya which is both park at turn signal light. Gumagana headlights h/l, turn at hazard lights.
    Ang nakakapagtaka, may parklight at turn signal ang left side marker only. So hindi sya switch. At hindi din relay.
    I already replaced lahat ng blade fuses sa kick panel at sa yung fusebox under the hood, but still wala pa rin.
    Baka may kelangan pako dapat i-check aside sa fuses?
    TIA Tsikot
    Quote Originally Posted by theshepherd View Post
    TIA Tsikot
    check electrical connections in the fusebox. sometimes, it's not the fuse but the fuse holders and the metal thingees under it.. lalo na kung may signs of hi temp (melting, blackening, distortion).
    good luck. ahh.. my aching back..
    Apr 2010
    Thank you for the reply sir. So kelangan ko baklasin ang fuseboxes pala. Sinabi mo pa sir. Sakit na ng likod ko kakadungaw. Baka po pwede nyo ako bigyan ng idea ng circuit ng parking lights? From the combination switch tapos relay ba o fuse?
    TIA
    Apr 2010
    Still wala pa rin parking lights. Cant feel my lowerback anymore. Baka may recommended shop or person kayo na mahusay at magaling mag rewire ng parking lights?
    Salamat tsikot.
    Salamat tsikot.
    let's see... try and check the relays. i guess i forgot about these earlier because our first cars had no relays, only direct battery-and-switch connections.
    Apr 2010
    Regarding the parking light relay, I think I found it. Sa may kick panel fuse box, above that. Parang cylindrical yung top portion then it has 4 prongs placed in a socket. It ticks when I twist the parking light switch. The only light that turns on would be the left side marker. But the thing is, if I flip the turn signal to the left it should also blink but its not. Only the other side blinks on turn signal but no parking lights.
    I'll try to replace it then.
    Jul 2012
    about park lights.. legal ba gumamit ng blue or any other color basta wag lang red as indicated by LTO? or baka hulihin ka rin kapag blue?
    Jun 2006
    Just use the regular white bulb or white LED.
    any other color just looks off.
    Quote Originally Posted by nashimoto View Post
    park lights, i think, are not required by law. you may use any light color except those forbidden in the rulebook.
    but if i may lecture.. yellow, orange, and white, are the colors deemed bright enough to be used as park lights.. using other colors, in my opinion, would be a lapse in sound judgement.
    basta kapag na-aksidente, handa mong sagutin ang "hindi ko nakita ang park lights niya, e".
parking lights
