Results 1 to 6 of 6
    Sep 2013
    Good day mga Sirs!
    I am a newbie here so please bear with me, hehe.. :hieveryone:
    I have a problem with my honda esi '94, while I was driving sa SLEX papunta Manila napansin ko na bigla na lang naglight up yung "check engine" na icon sa may dashboard then after awhile bigla na lang din nagflat "0" yung mga gauges ko (speedometer, accelerometer) pero continue pa rin po ako sa pagdrive so I stopped by sa gas station sa SLEX going to manila and I ask for some help, then someone said kailangan ko daw dagdagan yung brake oil so ginawa ko yun then nawala naman yung "check engine" so I continued driving pero gauges ko are still not working, while we were approaching Filinvest exit umilaw na naman yung check engine hanggang sa makauwi ako ng bahay di na sya nawala.
    di ko alam kung may kailangan na ba palitan or ipaayos. :question:
    hmm.... baka failing ECU?
    hwag naman sana.
    Sep 2013
    nasa how much po kaya pwde gastos pagpapachek? tsaka meron po ba kayo recommended na shop/mechanic somewhere in Muntinlupa?
    siguro bro, the best nyan is to have it scanned first, para matumbok ang sira.... para di ka na din magastusan na kung ano ano ang pinalitang pyesa pero hindi pala dun. pag scanned, direct to the point and diagnosis and parts replacement ay one hit.
    cannot recommend a shop in muntinlupa, but kung kakayanin, i am recommending servitek alabang (in front of toyota alabang). may scanner sila dun.
    check the vehicle speed sensor on the transmission, that's the one causing the check engine to illuminate
    Jul 2010
    Quote Originally Posted by t2erns View Post
    +1 on this
Speedometer gauge "0", check engine light is "ON"
