Page 3 of 7 FirstFirst 1234567 LastLast
Results 41 to 60 of 383
    Jan 2008
    installed SAE connector ..
    wala na bukasan engine bay to charge [emoji106]
    Nice.. nilagyan mo ng diode and fuse?
    ninja mods meron kaya yan anti-rust protection?
    except for the electrical plugs that appear to be protected naman by weatherproof cover, is there other iron there?
    puro plastic naman bro [emoji23]
    meron bro and tinest ko yun fuse, napabili tuloy ako spare kahapon.[emoji23]
    Mar 2018
    Thumbs up!
    ^thanks bro!
    gusto ko gayahin chris fixx sa youtube bro pero tagalog with bisaya subtitle [emoji23]
    kaso boses ko parang bading eh [emoji23][emoji28]
    ^thanks bro!
    Let us be the judge.[emoji16]...or...ask OB, the vlogger-to-be, dub?[emoji106][emoji4]
    Good ninj, how much moolah & man-hrs did you spend for this ninja mod?
    less 500 php for the SAE connectors and total 2 hours bro. only because im OC and i wanted it clean, and nothing else to do yesterday hehehe
    2Pcs SAE Power Socket Sidewall Port Weatherproof SAE Quick Connect Solar Panel Mount Universal Flush-Mountable Connector 12AWG SAE Cable for Solar Generator Battery Charger | Lazada PH
    https://tinyurl.com/t5avm4h
    may 1 pa ako SAE weatherproof (1st link) if you want, i can give it to you. afaik pwede sa ctek mo ito
    Pwede rin dyan yung trailer connector may 5 at 7-pin nun, or yung gamit sa trailer container van. Less than P500 lang yung pares at zinc alloy body with ceramic insulator. Or pwede din Anderson connector designed talaga for battery.
    Mar 2004
    This is not original?
    not sure bro
    nega and positive lang ito e
    not sure bro
    Trailer connector bro, same as nakakabit sa hitch receiver at semi-trailer trucks. All metal weatherproof hindi lulutong plastic sa UV at acid rains. 30amps yata max nyan pwede mo parallel to increase current.
    Or this Anderson, UV resistant gamit sa battery system ng EV, UPS, trailer extended batt, could carry up to 200amps
    Jul 2019
    Kumusta Sir Ninjababez yung ctek charger niyo? Nagagamit niyo po ba this enhanced quarantine and kumusta naman po ang charging niya?
    Im Planning to buy ctek charger.
    Salamat po
    Sep 2006
    Now I'm torn, should I buy a smart battery charger or a portable charger/jump starter/powerbank.? My concern is being able to start the car if my battery died down on me somewhere inconvenient or in the middle of the night.
    A smart charger would let me plug in and charge my battery using a wall outlet (hopefully available) and wait for some time to get my battery enough juice to start the car. However, A portable jump starter would start the car conveniently, as long as I regularly charge it and make sure it has enough juice to do its job. Tama ba intindi ko?
    tama po.
    but i am confident, you can afford both. heh heh.
    either product, has limitations on use.
    buying both, and those limitations diminish.
    may i recommend,
    the charger stay in the car or at home. always bring the powerbank in the car. many parking spaces have no access to a mains receptacle.
    if your car is MT... how confident are you at push-starting?
    it needs no powerbank or charger.
    Sep 2006
    tama po.
    may i recommend,
    Thanks for the tips doc.
    Ahh yes, one of the perks I miss when I had my MT car, I was less worried about these battery issues.
    A smart charger, battery tester(those that read CCA and internal resistance), and onboard volt meter should keep your peace of mind. A jump-starter kit is as good as the health of its internal battery, i'd rather bring jumper cable battery-less thing to worry.
Smart Car Battery Charger
