Results 11 to 18 of 18
- Jun 2005
- 164
April 16th, 2008 01:56 PM #11Ayos yang ganyan. Yung akin 7 yrs na, ok pa naman. Sobrang convenient at mababawasan ang time mo sa shoulder, so lumiliit rin risk na mabangga.
April 16th, 2008 04:55 PM #12
I have one na lagi kong dala for emergency I bought it for 400 pesos. More than two years na sakin ok pa naman and I use it everytime bumababa ang psi ko. Siguro once a month. Swertehan lang sa pagbili.
What I did was naglagay ako ng on/off switch malapit dun sa pump para hindi hugot ng hugot everytime papatayin yung pump. Saves me time and energy sa pagbalik-balik sa loob ng oto
April 16th, 2008 10:55 PM #13
Yung sa amin pala tatak nya "Interdynamics Laser air compressor"...had it since 1989.
I think Concorde in SM Megamall still sells this. A very good buy; take my word for it.
April 18th, 2008 05:09 PM #14
I have a couple of these air compressors and both of them still work okay after more than 5 years. Very handy in case of an emergency when you needed to inflate your tyre and ran a few kilometers to have a tyre change....
5808:bee:
April 18th, 2008 07:58 PM #15
one time, flat yung focus ng kaibigan ko chick at nagtanong sya kung may portable compressor ako.
labas kagad yung bili ko sa ace worth 600 yata.
nakaka 20 psi pa lang, bumigay na.
yabang ko pa naman at lagi ako handa
pero at least nadala pa nya sa vulcanizing shop with 20 psi.
May 1st, 2008 08:19 AM #16
mayron ako at napakinabangan ko na sa car ko ng ma flat minsan.
na inflate din naman up to 30psi sa indicator ng pump na yun pero ng makarating ako sa vulcanizing shop at pakargahan ng tama, 21psi lang pala. wala namang butas gulong ko mali lang gauge ng pump. ok lang. bottom line is, napakinabangan ko naman kahit papaano.
bago ko binili yun (SM Southmall) nag test muna at pinaabot ko ng 60psi yan bago ko binili(binaluktot yung dulo ng hose at pinaandar) if my memory serves me right naka pangatlong palit ng unit yata kami sa pag tetest bago naparating namin sa 60psi kasi di tumataas ang reading nasa first grad lang which is 20psi (daw!!) yung first two units. hehehe.
250psi pa gauge nun "too good to be true." kasi sa hitsura at materyales lang mukhang di aabot sa 100psi at sasabog na eh.
May 1st, 2008 09:40 AM #17
i used to have one, madaling masira. I bring a machanical pump along, over ten years (may be even more, sa bike ko pa yata to nung single pa ako) it still works without fail.
May 16th, 2008 03:03 PM #18
mas reliable ang double barrel foot pump kesa sa yung mga cigarette powered air pump. yung liteace namin napahanginan ko without jacking up the tires. :D
They're hell-bent on sustainability kasi... even at the expense of a shorter lifespan from their...
BYD Philippines
