Mga ser tulong naman po, yung signal lights ko po mabilis mag blink. yung sa right side na harap hindi na umiilaw yung likod naman gumagagana pa kaso mabilis mag blink ano po kaya ito? fuse?![]()
same here. hindi lang mabilis mag-blink, kakapalit ko lang nun isang araw, bilis din mapundi! any thoughts on this? =(
thanks
Next time you change the bulb clean the socket out real well. Use some PB blaster, the oil might help a bit. Are you certain that your using the correct bulbs? Give it a good cleaning and try again. The reason the turn signal blinks so fast is because the circut is interupted or wrong bulb, the tail light and brake light are usually two different bulbs.... since the front works, it is not a fuse issue, replacing the bulb is not very difficult and the bulbs are not very expensive, so clean it and replace your bulbs.
