Results 1 to 14 of 14
    Jul 2012
    2014 Vios 1.5g Manual
    Good morning mga Sir!
    Anyone here nakaexperience yung habang nakafullstop sa traffic.. nakaneutral.. biglang magquickshutdown ang buong auto.. lights, aircon, engine (basta mga naka ON) then magturn on agad naman lahat (dahil siguro nakaengage yung key sa pag on) PWERA ang engine? Parang yung biglang nagrestart na computer..
    Three times na nangyari.. Kapag naka neutral at stop (luckily).. Battery is still new.. Walang naman warning sa indicator lights ng dashboard.. bagong tune-up din ang auto.. everything is normal kung tutuusin.. nakakaworry lang yung may sumisingit na ganyang incident (di siya everyday) pag minsan..
    Sensya na.. Not sure kung sensor related siya or anuman.. TIA..
    Aug 2004
    Quote Originally Posted by Dusty View Post
    There's something loose. Simplest would be battery cables, but it could be something more problematic.
    May 2011
    That would be loose power cable or loose ground wire. The most common cause is corrosion on the cable clamps. Test but running the engine and do a wiggle test on the battery cables and the negative cable to the body and to the engine block.
    Jul 2012
    Quote Originally Posted by mina_nuka View Post
    Thank you so much..
    Noted mga sirs.. Any chance din ba na sensor-related?
    Jan 2009
    If the engine's been running, removing the battery should keep it running... albeit at a slightly lower RPM. My guess would be a loose or defective main relay or main fuse.
    Jul 2012
    Yes.. Been running (more than 30 mins.).
    Thank you sir..
    Mga Sir, from QC po ako, commonwealth area.. I'm hesitant to have my car checked sa Toyota Commonwealth (CASA).. Any suggestions para maayos yung concern ko?
    Dec 2009
    ^Spark plugs need stable electric supply
    Sent from my GT-P3110 using Tsikot Forums mobile app
    Feb 2017
    Fuel pump?
Shutdown(during neutral) - Toyota Vios 1.5G manual
