Results 21 to 40 of 48
    the only advantage for me is that it's a sealed battery. you can mount it which ever way you want even upside down. for 16 thou, I rather keep my vehicle upright.
    Dec 2002
    What's the warranty on Optima batt?
    Consider the alternative, AC Delco at P3.6k with 2 yr Replacement warranty. For about the same cost, you change every 2yrs for the next 8yrs but have a replacement warranty for peace of mind.
    Think Optima distb is the same as Redline oil dealer.
    ungas, my friend is selling optima batteries, he has the red top model 850 for SUV's, i don't know if its the one ur referring to, its P8000+ only, they don't know of a 34/78
    The 34/78 is the new model number. I think this was used to be the 850 model too. Same top and side terminals.
    Could you ask your friend if he has the specific size Yellow Top or Red Top for a Nissan Safari and can they customize brackets? Kindly PM your contact or their contact numbers. Thanks.
    EDIT: I seem to notice that Optima has reverse polarity versus our local brands. As far as I can remember our local brands have positive terminal on the right not on the left as per attached pic.
    For 8k, I'd say go for it as long as may warranty. I have a friend who used a red top and lasted for 5 years.
    Some(car audio enthusiasts) also use the yellow top as the main battery even if optima recommends the red top. You may use it basta make di ka ma-diskargado.
    Interstate batteries are also good.
    pwede naman daw upside down yan, so upside down mo nalang ikabit para di ka na mag extend ng cable.
    yung frontier, reverse polarity din ang batts.
    Signature
    Iba ang Optima na primarily for starting lang and iba din ang model na designed for powering stuff. Sorry I don't know which is which. Nabasa ko lang sa Montero Forums nung diniscuss nila in detail ang construction and engineering ng Optimas. hehehehe.
    Jun 2003
    ei baka may yellow top yun friend mo? PM me... thanks!
    Jun 2003
    ei guys, this is what i saw sa optima website...
    san kaya ito? pano pumunta dun?
    http://www.optimabatteries.se/contac...ines&freetext=
    Superior Motors Supply Corp.
    1026 Guillermo Masangkay
    Manila
    Philippines
    Phone: +63 2244 0309
    Fax: +63 2722 15 09
    in case someone goes to this store, pa update naman if they do carry it and how much...
    cardo, yun nga yung store ng friend ko, ungas try calling them
    Jun 2003
    a ok! pano directions punta jan? hehe sorry promdi kase ako eh
    Ah sa G. Masangkay yan sa Sta. Cruz near Recto. It's basically a one way street coming from Bambang St. passing Recto towards the end street which I forgot the name. Malapit na yan kina UE Auto Supply.
    If you're coming from Legarda via Recto, turn left at Masangkay St. 4th stop light from Avenida/Rizal Ave.
    xox::: Salamat, I'll try to contact them on Monday. Any name that I need to look for para may referral discount?
    EDIT: Btw, parking there can really be a hassle. Try to look for a pay parking lot. And walk to the store.
    ungas, no need for referral their prices are mostly fixed, even we don't bother to ask anymore gud luck
    May I ask, are you using Optima batteries too?
    Update ko lang:
    SUPERIOR MOTORS SUPPLY COMPANY
    ADDRESS
    #7 Dr. Garcia St.
    Quezon City
    TELEPHONE
    (632) 3741737
    Their office is behind Maxima Tractor, just after Pegasus Club. Sarado na pala yung Masangkay store nila.
    i used to use optima, not anymore, can't remember how long it lasted though
    So the final question; Is the 8,500 Optima red top battery worth its value? I've heard some people use it for 3 years with winch pulling and still works upto now.
    I don't mean to be rational, but primary applications are: starting the engine, powering the sound sytem, electrical winch and who knows, maybe a portable fridge! Plus the fact that it can sustain the vibration and jarring from offroad use.
    If you have extra money why not? Get the red top. The yellow top has a faster charge rate and faster release of energy(good for audio) but the downside is you can't afford to let the batery die.
    With the red top, it was built so that you can recharge anytime the battery dies and this won't affect the life span of the abttery.
    I just checked their office, with Red and Yellow Top in stocks. Kaso yung Red Top reverse polarity, tama nga hinala ko. Pwede naman baliktarin ang mount ng battery. Ang ayaw ko lang masyadong batak na mga wirings. Not enough looms to spare for engine vibrations.
    Sayang, sakto na sana yung 34/78 Red Top, di lang umubra sa polarities. Meron silang yellow Top which has the correct polarity side that I need, pang Civic models daw kadalasan kinakabit, specs are almost the same as 1SMF, mataas lang ng ilang inches. Di naman pwede sa battery console ko maliit, kundi kakalog-kalog.
    uh yon pala yung OPTIMA Battery???? parang may nakita ako sa workshop namin ah hehehehe.. Check ka nga sa SAP system baka stock Item yan... di bale na mag bitbit ako ng bagahe hahaha
