Results 1 to 10 of 10
    magandang hapon mga tsikot members.
    newbie lang po at may urgent inquiry tungkol sa nissan serena (subic) ko na medyo maraming sakit.
    would like to ask for information on shops na specialists (on nissan serena subic) sa mga sumusunod:
    aircon-- hindi lumalamig kung trafik
    electrical-- mabilis ma discharge ang battery
    body-- may scratch at dent dahil nabangga ko ang gilid ng serena habang papasok ng gate.
    thank you sa tulong nyo.
  2. #2
    Quote Originally Posted by dyaryo_boy View Post
    eto for each issue:
    either mahina na ang compressor mo, in my liteace, yan ang sakit, ready up to10,000 for this this. palit compressor(good and working surplus/refurbished, pag bagong compressor, be ready 20 thousand or more!), general flushing, expansion valves and drier replacements, linis, at palit mo na to r134a. check mo aux fans mo sa condensers, be sure they are all working.. may thread si mang mario dito, search mo nalang un ang tsikot-recomended shop. wag ka palit to sanden. ang nissan either hitachi or calsonic ang brand.
    have your alternator repaired/replaced. saan area mo, may alam akong pingkakatiwalaang gumagawa ng alternator while u wait. mura lang maningil. sa may quirino ave going to novaliches un..PM me kung gusto mo malaman. ready up to 5,000 pesos, at palit ka na ng atleast 90AH to 110AH para sulit ang pagpalit mo...
    sa suking body shop mo na yan pabanat, kung maliit lang pwede masilya, pero kung malaki, papapukpok mo yan....
    hope this helps...
    maraming salamat sir!
    i just located the thread tungkol k mang mario, malamang pumunta ako sa kanya next weekend.
    sa may makati/mandaluyong area ako, pero im interested dun sa alternator repair that you mentioned. will pm you.
    salamat ulit.
  4. #4
    replied sa PM po nyu..
    ask ko lang yung serena po nyu ba yung madaya-->may nguso (for immediate fillers like ATF/water,wahsers at spare donut tire) nga pero under the seat ang makina.. CD20T(2.0 turbo diesel) po ba?matic?
    yes, yung nga mismo sir. 2.0 turbo diesel matic. 1996 model ata ito, yung serena fx rio. common problem ba yung mga nabanggit ko sa ganitong serena? btw salamat dun sa directions re fargo. thanks
    Quote Originally Posted by alwayz_yummy View Post
    sir rion, maraming salamat sa advice.
    yung aircon, naalala ko pinalitan dati (july2006) yung eveporator, pero natatalo pa rin ng init ang lamig, tsk tsk. ok naman daw ang freon level last time i checked, but i wil have the other items you mentioned checked soon. salamat!
    yung battery, i have tried removing it para icheck kung mamatay, hindi naman namatay. ang sabi nung tumingin dati baka raw mahina ang pagcharge ng alternator kaya nadidiskarga ang baterya, so il have this checked as well soon.
    yung bangga, tama ka sir, kasalanan ko lang kung bakit nangyari yun. ngayon kelangan tuloy gumastos para ipagawa, hehe.
    salamat po ulit!
    Quote Originally Posted by rion View Post
    aircon-- hindi lumalamig kung trafik...
    check muna for leaks, have the freon level checked weekly to see if you have leaks...
    if freon level is still the same...
    check the compressor belt if it's tight.
    check the aircon condenser/aircon radiator is having sufficient cooling.
    see if your condenser is functioning normal (ask experts)
    see if the fan is powerful enough to cool the condenser.
    hook another fan to the condenser if possible...
    compressor should be the last thing to be fixed or replaced since it costs much... even with a bit loosy compressor, you can still improve cooling by help cooling the condensers to the max...
    electrical-- mabilis ma discharge ang battery.
    check if it's charging, try turning the engine on > then remove the battery while engine is still running > use amper meter on the connecting terminal > rev the engine up to 2500 rpm and see if the amp meter indicate that it is charging...
    amp meter is cheap... if it isn't charging, baka may problema ka nga sa alternator...
    be more careful nextime?
Serena Subic Experts (Aircon/Electrical/Body Repair)
