the IC is on the alternator. 16 volts is only 2% above 15.6 volts, acceptable na yan since it is within the error range of the volt meter. ano ba battery mo, maintenance free or conventional? if you have a conventional battery and you are adding water more than normal then that is a sign of overcharging and you'll need to look into replacing the IC. but if not then you have nothing to worry about.
