Results 1 to 6 of 6
- Jul 2005
- 122
April 17th, 2009 07:06 PM #1when i turn on the headlights or do a headlight flash, the radio stops for a while and the rpm tach flicks to zero then back to normal again.
when i got home, i tested it with a volt meter while engine is on. it registered 14+V, when engine is off, its 12.7V. So I guess my alternator is fine.
Mga guru, what could be the problem and the solution?
di ko alam kung san ok magpagawa when it comes to electrical. i'm from mandaluyong.
car is civic 96 vti. Thanks in advance.
THE AUTO SPECIALIST
- Mar 2006
- 607
- Jul 2005
- 122
April 18th, 2009 01:04 PM #4thanks bambino, yep, i had the ground wires and terminals cleaned, medyo steady na ngayon at wala yung dating sumpong. will still have to observe it.
THE AUTO SPECIALIST
- Mar 2006
- 607
April 18th, 2009 10:02 PM #5you can also put an extra ground wire to the body to reinforce the old existing wire.
- Jul 2005
- 122
April 20th, 2009 09:27 AM #6* bambino, pwede din pala yun to add another wire to the body pang-reinforce sa existing wire? thats good.
Thanks also to ghosthunter, actually, pinapalitan ko na din yung terminal para sigurado.
Denali Lights, Dial Dim, & Soundbomb Review—Is It Worth The Premium? | Behind A Desk MotoDeal
Auxiliary Driving|Fog Lamps
