Results 1 to 8 of 8
- Feb 2008
- 76
February 26th, 2010 04:21 PM #1mga sir tanong ko lang po kung meron kayong idea kung bakit bumabagsak rpm ng kotse ko(nissan series 3) kapag titigil ako, normal naman po rpm ko kapag running ako walang fluctuation ng rpm, pero kapag tapakan ko clutch at break bumababa rpm ko tapos minsan namamatay yong engine. Ang hirap kasi lalu na kapag trapik nakakatakot tuloy dalhin kotse sa malayo baka biglang di na magstart uli. Sana matulungan nyo po ako..TIA
- 168
- Feb 2008
- 76
February 28th, 2010 08:08 PM #3kaya pala bumabagsak rpm ko namamatay pala sparkplug ko huhuhuh puro carbon pinalitan ko ng bago yon puro carbon uli patay na uli engine ko.. sinilip ko lagayan ng SP wala naman ako makitang langis tuyongtuyo naman, bakit kaya grabe magcarbon to? wala naman ako napapansin paghina ng hatak malakas naman engine yon nga lang kapag medyo malayo na natakbo ko kikilig na engine tapos namamatay pagkalas ko ng SP puro carbon na.. mga paps baka may input kayo..TIA
March 1st, 2010 08:56 AM #5
If it dies at idle due to oil, the sparkplugs should actually be wet.
If they're black and it's dying, it could be the MAF is on the fritz, and the car is running way, waaaay, too rich (too much fuel).
But you say the sparkplugs aren't sparking properly? Check your distriutor cap and wires... might have crossfiring at the ignition wires...
- Feb 2008
- 76
March 1st, 2010 12:50 PM #6mga Sir thanks for your reply, lahat ng sparkplug ko puro carbon to siguro yong cause kaya nagfailed sya magfire, wala naman ko nakikitang oil sa tip nya basta puro carbon lang, I already check the distributor cap and the tension wire ok naman wala ako nakitang problema. Sa ngayon nagbawas muna ako ng oil kasi naparami ata yong lagay ko above the max level of deepstick as of now di pa pumapalya engine ko mamaya check ko sparkplug kung may carbon uli sya. Maraming salamat po.
- Feb 2007
- 89
March 1st, 2010 06:00 PM #7Fuel injected ba engine mo? baka marumi throttle body. Nangyari na sa kin yan, namamatay lagi engine, gusto madiin tapak sa gas, di naman nakailaw "check engine".
- Feb 2008
- 76
March 1st, 2010 06:26 PM #8yes sir kenshinx EFI na engine ko, di naman nakailaw yong check engine ko, pano ba linisin yong throttle body kaya ba DIY yon? Salamat po..
What vehicle and what's your budget?
