Results 1 to 6 of 6
    May 2009
    mga papi, naexperience new na ba to? pag nagrereverse ako. minsan walang ilaw yung reverse light. pero pag ginagalaw ko ng konti pabalik yung kambyo. umiilaw sya ulit. pag sagad yung kambyo sa reverse minsan meron, minsan wala, kailangan pang ia adjust yung kambyo pabalik ng konti. pano ba to ayusin. tia.
    san po may nag aayos nito? cainta area po sana?
    Feb 2009
    Quote Originally Posted by desh2129 View Post
    desh2129,
    unfortunately your sentra placed your PRND2L switch under the battery tray. when the battery spews electrolyte, it drips straight to the PRND2L switch. it is not too difficult however, to repair the switch. take it off the transaxle and tear it open on a workbench being careful not to lose small springs and contacts. there has to be worn contacts inside. you can use a light sandpaper to resurface the contacts and it should work fine. or purchase a replacement( dealer part only) for a fortune.
    jick
    May 2009
    desh2129,
    jick
    Sir jick,
    thanks for the quick reply, di ko pala namention na manuat yung sentra ko. sorry. San po ba located yung reverse switch?
    Feb 2009
    Sir jick,
    desh,
    your back up light switch is located right nex to the shift levers on the transaxle. it has one wire connected to it. usually mounted towards the top of the tranny.
    jick
    May 2009
    desh,
    jick
    thanks sir, you're the man.
    Feb 2009
    desh2129,
    always been. ever since. dja fix it?
    jick
reverse switch ng sentra
