Results 1 to 15 of 15
    Dec 2009
    mga sir saan pede bumili ng surplus alternator near alabang area.mukhang bumigay na yung alternator ko.last day i went to san pedro naka pag start pa ako nung morning and 1click lng tapos along the way biglang nawala yung busina ko then nawala yung aircon and yung light sa instrument panel nag start syang humina like nung signal light di mo na makita yung light sa instrument panel.and bigla na lang ako namatayan.pero if itutulak tapos jumpstart ok naman pero after 5 mins. patay na uli.wala naman problem sa engine.(honda civic lx ph15)tnx...
    Quote Originally Posted by hyblaxx_24 View Post
    Sir meron dito sa Binondo kaso sobrang layo lang para sayo kaso mga Recon po ito. sure naman ito na tatagal kasi good as brand new ito at may 6 months warranty
    Jun 2008
    sir may i suggest you try evangelista, makati... they have a lot of surplus parts there, just be careful of "agents" that will over-charge. i suggest you got straight to the store. we got our surplus transmission at INAKI for my altima automatic.
    Dec 2009
    mga sir i got my surplus alternator and installed it.the problem is biglang nawala yung aircon akala ko sira then pina troubleshoot ko ok na uli after ilang testing nawala nman yung ilaw sa dashboard tapos pati parklight,headlight at taillight.ok nman yung ibang accessories like radio,and yung sa hazard.tinignan uli at nung test nya nasunog yung relay socket at konting wire then nag sasalubong daw yung negative sa socket. pinag tataka ko lng bkit pati ilaw sa dashboard nawala.nag palit lang naman ako ng alternator.tnx...
    ilang amperes ba yung nilagay mong surplus baka masyadong mataas hindi kinaya ng stock wiring.
    Dec 2009
    Quote Originally Posted by a3n3as View Post
    90 amperes yung pinalit ko.
    i sugest you are better off buying a reconditioned one rather than surplus, atleast reconditioned ones are newly rewind, i've had bad experiences with surplus alternators. and the price difference isn't that much.
    Maaring hindi nag automatic ung voltage regulator. Paukat mo ung voltage sa battery habang nasa almost redline dapat yan nasa 14volts lang.
    Kung ok naman baka may nasira kang grounding connections.
    Jun 2008
    Quote Originally Posted by reym View Post
    Agree ako dito.
    Jun 2004
    If I were in your place I'd take the rig to Rey's Electrical (15th Ave Cubao) or to Wizzard (along Morato). Pa check mo na yan don. They also recondition alternators with warranty pa.
    Mga sir, my trusted shop ba kayo nag sell ng maayos na Alternator here at Q,C? sana meron along commonwealth or banawe
    Oct 2008
    Sir, bumili ka na lang ng new kasi mga surplus my defect din.my root na hindi gumagana.
    na-solve na kaya ito ?
    Quote Originally Posted by stallion View Post
    Sir Stallion ano name and saan yung shop sa binondo
    Aug 2010
    i think meron din sa may antonio rivera st. parang 2 blocks before you reach tayuman. Red ang name ng shop. maraming recon doon. puede mo ring paayos yung sira mong alternator.
where i can buy surplus alternator?
