Results 1 to 15 of 15
    Jul 2015
    Mga boss, meron ba kayong alam na shop na nagpapalit ng resistor sa loob ng right passenger fuse box, nakita kasi ng mekaniko namen na sunog yung apat na resistor pero wala kasi syang mahanap na pangpalit, di kasi nagana yung panel gauge, honda accord 2001.
    Feb 2009
    Can you post the pictures? There should be no resistors in the fuse box.
    Could be fuses that look like resistors.....
    Like this?
    28.9K _/_/_/_/_/:waltz1:_/_/_/_/_/
    Jul 2015
    Like this?
    ganyan nga po yung hinahanap sir, san po kaya makakabili ng ganito para yung mekaniko na lang ang magkakabit?
    Mar 2015
    Quote Originally Posted by 6thgenaccord View Post
    baka meron yan sa deeco
    These are soldered to save on space.
    If you can't find similar ones, and you need to get the car going,- solder a thin wire on each and nip (pinch) each of them.... They will act as a fuses...
    Jul 2015
    dinala kasi ng mekaniko yung parts, ang sabi kasi nya saken yun daw resistor sa loob ng circuit board ng fusebox.
    Oct 2015
    Sa decco.. quipo or cubao...
    Alexan.. quipo or megamall...
    Make sure lang na tama ang color coding.. may value kasi yan kung ilang ohms ang tawag diyan..
    Jul 2015
    maraming maraming salamat mga boss. magandang araw po sa inyong lahat.
    Jul 2014
    If hindi mo alam ung values ng resistors na papalitan, dalhin mo na lang ung resistors mismo para i-assist ka ng store attendant.
    Jul 2013
    usually 1 - 10 ohms fusible resistor rated * 2A. this is used in cfl and electric fans. hindi critical ito just as long as the amperage is not exceeded. temporarily, bili ka ng 2A fuse together with fuse holder. ang paginstall, bahala na ang car electrician mo.
    Oct 2015
    ^ agree..
    Nung around 90s e 0.50 cent lang ata yan. Baka ngayon 1 peso na..
    i can't seem to access the pictures, so i don't know what these items are.
    but if they are what i think they are, the color rings around them and the size, are the code to their resistance value and their power rating.
    any repairman worth his soldering gun, should decode these on sight.
    btw... wala ba ito sa owner's manual?
    Jul 2014
    I don't think it is in the owner's manual.
    The physical size of the resistor determines its power rating:
    1/4 watt - smallest
    1/2 watt - smaller
    1 watt - small
    5-watt - large
    10-watt - large 2x
    By the way, if you have a clear colored picture of the actual resistors to be replaced, post here and we will try to decode it so you will have an idea of its values before going to the store.
    Oct 2004
    Baka resistor block for low impedance fuel injectors yan...
    Depending on car, usually nasa 10R (10 Ohms) nasa mga 15-20Watts siguro each (enclosed sa ceramic case).
Resistor replacement
