Hi!.., bago lang po ako dito..,
can't find any threads which can help me..,
ayaw po kasi mawala nung warning light for open door.., even all the doors were already closed.,
what should i do?
what should i do?
my door jan n ndi nya n pupush ng maaus ung switch door..try mo close lhat den pag open mo ng isa i manual push mo ung switch,(isa-isa)pag nmatay n ung switch s alin mang door,un n ung ndi nya ma push ng maaus,gawin mo n lng lagyan mo ng goma ung tintamaan ng swicth s door...madali lng po yan sir...
Ganyan din problem ng vios ko. After mabaha, saka lumabas ang problem na yan. Hanggang ngayon di pa rin ma-solve. Almost everyday I remove the battery terminal to prevent it from being discharged.
Na-isolate ko naman yung problem. What I did is I set the dome lamp to turn-ON when the door is open. Tapos, inisa-isa ko pindutin yung mga door switch sa gilid. Yung isang door switch hindi nagre-respond everytime pini-press ko. I replaced it with a new door switch from the casa, wala pa rin!
Ang sabi, it's either the wires are grounded or the multiplex or fuse box underdash needs replacing. A brand new one costs P18,000. You won't find any surplus part.
Saan ko kaya pwede ipagawa to? Balitaan mo ko kung naayos na yung sayo ha. Thanks!
try adding a ground, baka nawala na yung contact. find the ground of the electrical to the door then use a wire then recta sa body pag nawala, kulang lang sa ground.
sir, san po sa malolos?., natry ko na po ipress pero parang hindi sa sa switch ang prob.., I've pressed the switch on one door nung una ayaw.., then biglang nawala.., okei na sabi ko.., pagbukas ko nung door sa driver ayaw nanaman.., then i try pressing the door earlier pero ayaw na.., tapos ayon palipat lipat lang yung naglolokong side nang door..,
Haitzzz..,
guess ko lng sir ha..malamang na shorted nga ung wire ng door switch kasi ground switch yan,iisa lang kasi ang wire ng apat na pinto na yan sir,my sugat ung wire at kumikiskis un sa body ng car mo..malamang po bumalik ung problema mo ...
malapit po sa puregold ..katapat po niya ay twinplaza at katabi po kami ng twinplaza ..may gate na kulay yellow..louie po ang real name ko..thanks po,pag sarado po ung gate katok lang po kayo....![]()
