Results 1 to 6 of 6
March 17th, 2015 11:48 AM #1
I noticed that my driver side rear brake lamp wont turn on whenever i step on the brakes.
The rear lamps do light up when i turn the park lights/head lights on. Kaya lang pag tapak sa preno nawawala ilaw ng tail lights.
I have already tried replacing the double contact bulbs, and interchanging it with the right side bulbs, pero ayaw pa din ang brake lamps sa kaliwa.
Nasa socket na kaya ang problema? Meron bang nabibiling socket sa side street auto supply? Thanks.
March 17th, 2015 11:59 AM #2
If it turns off [even the park light] when you brake, it is grounding bro.... Could be loose grounding....
Park light is 5W; Brake light is additional 21W (assuming that you have a double contact P21 bulb),- so if the grounding is intermittent,- both could turn off.....
26.0K:poop:
March 17th, 2015 03:25 PM #3
March 17th, 2015 04:03 PM #4
Double contact sockets have 2 wires in the middle (one for 5W-park light and the other for 21W-brake light) and one on the side- GROUND,- which is connected to the body of the metal socket. If you have a ohm meter (multimeter), check the integrity of the connection of the ground wire with the socket,- could be loose or the ground wire to the other ground wires of the other sockets, or the body of the vehicle.....
Kayang-kayang DIY iyan!
26.0K:poop:
March 17th, 2015 05:15 PM #5
March 17th, 2015 05:23 PM #6
