Results 1 to 6 of 6
- Jul 2011
- 1,711
October 2nd, 2012 09:54 AM #1Mga bossing share, ko lang incase ung power window ng RAV4 nyo ay ayaw din gumana at hinahanap nyo ung fuse.
https://plus.google.com/u/0/photos/1...18451521?hl=en
Ang problem ko lang now ay hindi pa ako nakakabili ng fuse kaya ung window ko nde ko mabuksan.
BTW para maisara ko ung window ko pinagshort ko ng susi ung terminal ng fuse sabay close ng mga windows.
- Jul 2011
- 1,711
October 2nd, 2012 04:30 PM #2update ko lang po, tumawag ako sa parts dep. ng Toyota Manilabay ang advise sa akin nung Ariel dalhin ko ung sample sa kanila at mag antay ako ng 2 days for the spare fuse to arrive.
I really need to find a more faster solution...
- Jan 2008
- 4,726
October 2nd, 2012 05:27 PM #3
October 3rd, 2012 11:24 AM #4
Fusible link ang tawag diyan. Murang mura lang sa mga auto supply/auto electrical supply yan. 30 amps yung pink colored niyan and huling bili ko is P25 lang ata. You can buy that practically anywhere.
- Jul 2011
- 1,711
October 3rd, 2012 11:32 AM #5Naka buy na ako sa autosupply, gumana naman kagabi pero kaninang umaga nag trip ulit.
Meron na po ba sa inyo naka experience ng ganito at ano ang naging cause kaya nag trip ang power window fuse.
October 3rd, 2012 11:46 AM #6
Kung nagtitrip yan at 30 amps then merong grounded somewhere or pwedeng may problema yung motor ng power window mo (masyado malakas kumain ng current). Wag mo palitan ng mas mataas na rated fusible link. Find the culprit and have it repaired or replaced. Pag pinalitan mo ng mas mataas na rating baka masunugan ka ng wires.
Share ko lang, nangyari sa akin yung napuputulan ng power window fusible link. Na-trace ko yung problem sa power window auto switch na hindi bumabalik. (May auto-release yun pag tumaas ang current when the window is fully closed pero pag merong stuck up, iinit nang iinit hanggang sa yung fusible link na ang maputol). Solved the problem by having the switch assembly repaired.
I received this email from Fleetguard Understanding coolant and recommendations I think this...
