Results 1 to 20 of 30
    Ano mas okey distilled water or coolant?
    May tint or wala?
    Coolant
    When: Every Fuel Stop
    Check your car's coolant level on the outside of the reservoir while the engine is cool. If the level is close to or lower than the "LOW" mark, add coolant up to the "FULL" mark. If the reserve tank is empty, remove the radiator cap (Do not open when the radiator is hot!) and refill as required. After filling the reserve tank and the radiator, reinstall the caps and check that the rubber gasket inside the radiator cap is in the proper position.
    IMPORTANT: Use the coolant recommended in your Owner's Manual only. Use of other coolants may result in corrosion.
    Oct 2007
    Quote Originally Posted by jimiboi View Post
    May tint or wala?
    Coolant
    Are you asking for help or something?
    Nov 2007
    May tint or wala?
    Coolant
    Distilled water only, i dont add coolant for some reason.
    syempre mas okay ang may tint, bawas radiation and init from the outside and also to hide important things inside the car.
    I dont think that he is asking question but rather giving a "tip".
    Aug 2007
    Quote Originally Posted by Esnie.com View Post
    ano yung reason bakit hindi ka gamit coolant?
    tipid mode?
    Jul 2006
    Distilled water will prevent mineral deposits from forming when using tap or mineral water, while coolant will prevent corrosion especially if your cooling system comprises of aluminum parts, as well as increase the boiling point of your system so your car won't readily overheat. I'd give it a 50/50 mixture to be safe.
    ^^^ Agree here. I normally use a 50/50 mixture of coolant and distilled water.....
    Also, tint is a big help.
    5808:bee:
    Nov 2007
    Quote Originally Posted by suv View Post
    i just dont trust coolant, 100% distilled water. Ang recommend ng mga radiator shop, common probem kaya nagbabara ang radiator dahil sa coolant; maybe misused, wrong mixture or no pms on coolant.
    anyway its up to if you want to add coolant, in the long run you will see the effect of using coolant.
    ^^^marami ng coolant na "pre-mixed" so no need to add water....kung galing sa CASA brand new naka coolant eh, so might as well just follow it...
    i also use coolant for my car ... it gives better protection for long-term use
    summer or not, i always use my folding shield (across the windshield) to protect the dahsboard from absorbing to much heat and of course it also helps cool the cabin
    110,000 km for the Rav4.
    100,000 km for the 323.
    Both are using coolants... no problem whatsoever.
    And I'd rather believe those Japanese engineers than your average backyard radiator shop.
    __________________
    bigbigcar.com Review: Mercedes-Benz C200 Kompressor Avantgarde
    Nov 2007
    Quote Originally Posted by mazdamazda View Post
    __________________
    YOU ARE VERY LUCKY BOY TO HAVE THAT!!! anyway 100kms too early to determine...........
    285kms 1985 190E benz we never used coolant, 100% distilled water.
Questions in keeping our Car Cool during Summer Time
