Results 1 to 14 of 14
    Jun 2008
    Good day to all !!!
    Nagkaka problema ako every time i do a right turn dahil kusang bumubusina ang car ko, Nagpalit kse ako ng Typr R steering wheel (1993 Nissan JX), ok naman sya after ma install walang problema, pro after 1 week nagulat ako dahil bigla na lang bumubusina pag liko ko ng kanan, so binaklas namin ng friend ko yung Type R na manibela, nilinis namin yung mga contact ng busina at pati mga dumi pati nilagyan ng tape yung mga pwedeng maging grounded, so nawala na ang problema working smoothly na after tyhat cleaning, hten after 1 week eto na naman ang problema bumubusina na naman ng kusa tuwing right turn.
    Mga sirs , tulong naman kung ano ang dapat gawin dito para mai ayos ana talaga, nakakahiya kse busina ng busina e
    Thank you in advance !!!
    may contact yung horn button wiring mo to some metal inside the adapter. that's the only thing that i see.
    Jun 2008
    * 1D4LV - sir sinubukan ko ngayong tanggalin ang horn button, kso bumubusina pa rin ng kusa kahit wala na ang horn button
    Nov 2007
    replace mo na lang busina mo sa ibang parts ng car mo then cut mo na line nyan original busina mo ,, pero kung madadala mo sa magaling na auto electrical yan baka makaya nila problem mo
    May 2007
    Perhaps, its a reminder that you are turning to the right. Like a navigation in your car, only....... its a horn.
    Okey so much for that!
    On most cars, the horn button acts as a ground, meaning, there is power
    to the horn at all times. The horn is activated by grounding the other wire, which is done through the horn button. Sometimes a wire that goes to the horn button gets worn and shorts out causing the horn to blow. kaya tignan mong mabuti yong mga wiring sa steering wheel mo at sa may steering column right underneath the steering wheel. Sometimes the horn button itself is faulty and causes intermittent honking. Check to make sure your horn button is not loose and is properly secured to the steering wheel.
    oh noes! your car is possessed!! :shocked:
    you need this guy
    just kidding....sometimes weird things happen when electrical parts have compatibility issues. kung di maayos ng electrician you may need to get rid of the part...
    you need this guy
    may option yan kung okey sa yo .
    magpakabit ka ng horn switch sa spot na okey para sa yo
    My best option kung stock pa horn mo. kesa ibayad mo ng rewiring yan, pakabit ka ng new horn (please see the loudest and baddest horn thread para makapili ka) free installation na yan. replace the wire with #18 stranded para malakas. Free na labor mo may new horn ka pa.
    Aug 2008
    mdali lang yan bumili ka ng tintwag na "boss kit" (i dunno if i spell it ryt) i2 yung prang round tube sa gitna ng steering wheel dun nka connect yung terminals ng busina and kung ndi ka mekaniko ndi nman siguro msama kung ipagwa mo na sa mekaniko yang pgkkabit ng manebela mo.
    Oct 2007
    This made my day.
    Naala ko tuloy uncle ko na galit na galit dahil namamatay engine ng volvo
    nya pag lumiliko sa kaliwa.
    Busina lang sa iyo, yon sa uncle ko namamatay engine pag nag left turn.
    Kamusta na kaya volvo nya?
    Jun 2005
    Baka naman may tumatawid na white lady!
    :eat: [SIZE="1"]3902[/SIZE]
    Jan 2003
    hahahaha! lately lang yun sasakyan ko bumubusina mag-isa kahit nakapark na at nakalock na yun pinto. as in isang mahabng busina na diretso. si misis natakot! baka may nagmumulto. checked the whole horn button wirings and the steering wheel pero ganun pa din! akala ko nga niloloko lang ako pero hehehe natakot din ako dahil as in bumubusina ng kusa at mag-isa.... it turned out na yun relay eh nakabaliktad and yun tape na ginawa kong cover eh nagmistulang cup ng tubig kaya nung napuno ng tubig eh nagshoshort yun busina! bubusina nga mag-isa......
    may relay ba yun horn mo bro? baka kapag liko mo eh may sumasayad na contact point kaya nagshoshort?
Help !!! Kusang bumubusina everytime i do a right turn !!!
