Results 1 to 10 of 14
- Jun 2008
- 20
August 4th, 2008 02:49 PM #1Good day to all !!!
Nagkaka problema ako every time i do a right turn dahil kusang bumubusina ang car ko, Nagpalit kse ako ng Typr R steering wheel (1993 Nissan JX), ok naman sya after ma install walang problema, pro after 1 week nagulat ako dahil bigla na lang bumubusina pag liko ko ng kanan, so binaklas namin ng friend ko yung Type R na manibela, nilinis namin yung mga contact ng busina at pati mga dumi pati nilagyan ng tape yung mga pwedeng maging grounded, so nawala na ang problema working smoothly na after tyhat cleaning, hten after 1 week eto na naman ang problema bumubusina na naman ng kusa tuwing right turn.
Mga sirs , tulong naman kung ano ang dapat gawin dito para mai ayos ana talaga, nakakahiya kse busina ng busina e
Thank you in advance !!!
August 4th, 2008 02:56 PM #2
may contact yung horn button wiring mo to some metal inside the adapter. that's the only thing that i see.
- Jun 2008
- 20
August 4th, 2008 03:24 PM #3* 1D4LV - sir sinubukan ko ngayong tanggalin ang horn button, kso bumubusina pa rin ng kusa kahit wala na ang horn button
August 4th, 2008 03:46 PM #4
replace mo na lang busina mo sa ibang parts ng car mo then cut mo na line nyan original busina mo ,, pero kung madadala mo sa magaling na auto electrical yan baka makaya nila problem mo
August 5th, 2008 02:40 AM #5
Perhaps, its a reminder that you are turning to the right. Like a navigation in your car, only....... its a horn.
Okey so much for that!
On most cars, the horn button acts as a ground, meaning, there is power
to the horn at all times. The horn is activated by grounding the other wire, which is done through the horn button. Sometimes a wire that goes to the horn button gets worn and shorts out causing the horn to blow. kaya tignan mong mabuti yong mga wiring sa steering wheel mo at sa may steering column right underneath the steering wheel. Sometimes the horn button itself is faulty and causes intermittent honking. Check to make sure your horn button is not loose and is properly secured to the steering wheel.
August 5th, 2008 07:40 AM #6
oh noes! your car is possessed!! :shocked:
you need this guy
just kidding....sometimes weird things happen when electrical parts have compatibility issues. kung di maayos ng electrician you may need to get rid of the part...
August 5th, 2008 07:40 AM #7
you need this guy
THE AUTO SPECIALIST
- Mar 2006
- 607
August 5th, 2008 08:27 AM #8may option yan kung okey sa yo .
magpakabit ka ng horn switch sa spot na okey para sa yo
August 5th, 2008 08:51 AM #9
My best option kung stock pa horn mo. kesa ibayad mo ng rewiring yan, pakabit ka ng new horn (please see the loudest and baddest horn thread para makapili ka) free installation na yan. replace the wire with #18 stranded para malakas. Free na labor mo may new horn ka pa.
Burberry Men Leather Jacket oskarjacket
Verifpro - paypal, ebay, banks, crypto, docs and...
