Originally Posted by
jimiboi
Ano mas okey distilled water or coolant?
May tint or wala?
Coolant
When: Every Fuel Stop
Check your car's coolant level on the outside of the reservoir while the engine is cool. If the level is close to or lower than the "LOW" mark, add coolant up to the "FULL" mark. If the reserve tank is empty, remove the radiator cap (Do not open when the radiator is hot!) and refill as required. After filling the reserve tank and the radiator, reinstall the caps and check that the rubber gasket inside the radiator cap is in the proper position.
IMPORTANT: Use the coolant recommended in your Owner's Manual only. Use of other coolants may result in corrosion.
