Results 1 to 7 of 7
    Feb 2003
    My power window sometimes works and sometimes it doesn't. very intermittent, di ako makakuha ng pattern. very annoying esp. pag kukuha ng parking ticket or magbabayad e.
    i took out the sidepanels to check the wirings and lubricate the parts but its still happening.
    what's next?
    Jun 2005
    If it works intermittently, baka loose lang ang terminal connections sa switch which is not addressed by just cleaning/lubricating it. It happened to my ride once at hinigpitan lang yung socket connections ng switch at naayos naman.
    Jul 2005
    honga baka loose connection lang bosing. check mo at higpitan tapos clean mo ulit tapos kabit na. sana gumana na sya palagi
    kung naririnig mo naman that the motor is running but the windows are stationary, it is possible na sira na ang gears nito that controls the windows....
    Jan 2004
    mga sir, mali yata tayo ng forum... sa workshop po dapat itong thread na ito.
    mga mods, pa-move na lang...
    Its possible the switch itself could be starting to fail.
    Feb 2003
    update, sinubukan ko sa tahimik na lugar... at hindi dun sa iniisip nyo hehehe...
    naririnig ko yung motor so i guess this rules out switch/connection problems baka nga nagsisimula ng mag fail yung gears...
    next question is should i change the motor altogether (surplus) or pa repair? i'm leaning towards replacement e. what do you guys think?
Power Window problem
