Results 1 to 10 of 10
- Feb 2008
- 46
November 18th, 2009 02:11 PM #1Mga Bossing,
My car is Corolla GLI 97,
I need help regarding sa window right side (likod), bigla na lang ayaw bumaba pero yung iba ok naman.
Advise po possible ba DIY at kung ano yung gagawin ko.
Salamat.
November 20th, 2009 05:02 AM #2
check the fuse first pero malamang isang fuse lang yan or one fuse per side. check mo rin yun power window switch. you can also open the sidings and check to see if may voltahe papasok ng motoror if motor na ang sira. i'm moving this to the electrical forum section.
November 20th, 2009 06:18 AM #4
Yup. Pero di siya gaya ng aux fan o alternator. Di na na repair yun, palit na sigurado pag nasira.
November 20th, 2009 07:13 AM #5
kung umaandar ang motor (mararamdaman naman yun) pagnaka on ang switch niya, baka yung contact ng plastic spool ang nasira. yung dmax ko kasi ganun ang nangyari... yung plastic spool na eto ang ini-ikutan ng steel cable ng window.
November 20th, 2009 07:57 AM #6
based on my experience, pag ayaw gumana yung switch sa passenger side, hindi din gagana sa driver main control switches. either yung problem wala sa motor baka nasa switch, try checking both switches sa driver and passenger side.
November 21st, 2009 12:09 PM #7
October 21st, 2010 03:21 AM #8
- Apr 2009
- 544
October 21st, 2010 06:37 PM #9pa tingnan mo sa electrical shops . sa experience ko malamang poor contacts
yan sa switch or possibly bumigay na motor mo. yung sa akin sa right side
before ayaw gumana, naayos ko yung contacts sprayed contact cleaner. but
nung tumagal natuluyan na rin kaya pinalitan ko switch.
November 3rd, 2010 10:48 PM #10
Update lang po, napalitan ko na yung switch sa front passenger side, using the master switch, wala na siya problema, pero pag yung switch mismo sa door ang ginamit hindi siya tumataas, pambaba lang.
Ang weird pa dito eh yung 2 windows naman sa likod ang hindi bumababa ngayon after replacing the switch on the front passenger side.
