Results 1 to 10 of 10
    I was just wondering kung pwede kong palitan ang stock na hi-tension wires ng liteace ko.........what would you guys suggest?
    u mean aftermarket wires?
    for a relative stock engine.....stock wires is highly recommended
    naguguluhan kasi ako eh......does it mean that I can't use for example a SplitFire Hi-Tension wire for my 7K engine?
    nielsn::: IMHO, Save your money na lang as Those really wont give you any tangible results. IMHO lang po :wink:
    IN fairness sa aftermarket plugs, mas swabe/soft ang takbo ng makina.
    Spark plugs na lang ang palitan mo, ex. Bosch Platinum (long life) or 4-tip (higher performance), spitfire ,etc.
    With a stock engine and ignition system, just use the stock wires and properly gapped stock plugs...
    My two cents.
    Ignition wires do increase their resistance with age so replacing them will improve performance. Performance aftermarket wires will yield very little if none performance gains if you have a realtively stock engine. Just get the stock or OEM wires and save your money. Check your spark plugs also while you're at it. :mrgreen:
    If you MUST repalce the wires, only 2 brands works and last. NGK wires and Magnecor.
    Thanks for the info guys.....I'm currently using Bosch Super 4 spark plugs.......and stock wires and ignition........it's running superbly well naman.......I'll take your advice on this.....save my money na lang........:D
Help on Hi-Tension Wires......
