Results 1 to 10 of 10
October 25th, 2002 05:11 PM #1
I was just wondering kung pwede kong palitan ang stock na hi-tension wires ng liteace ko.........what would you guys suggest?
- 14
October 25th, 2002 05:38 PM #2u mean aftermarket wires?
for a relative stock engine.....stock wires is highly recommended
October 25th, 2002 05:54 PM #3
naguguluhan kasi ako eh......does it mean that I can't use for example a SplitFire Hi-Tension wire for my 7K engine?
October 25th, 2002 06:08 PM #4
nielsn::: IMHO, Save your money na lang as Those really wont give you any tangible results. IMHO lang po :wink:
October 25th, 2002 06:29 PM #5
IN fairness sa aftermarket plugs, mas swabe/soft ang takbo ng makina.
October 25th, 2002 08:22 PM #6
Spark plugs na lang ang palitan mo, ex. Bosch Platinum (long life) or 4-tip (higher performance), spitfire ,etc.
October 26th, 2002 12:09 AM #7
With a stock engine and ignition system, just use the stock wires and properly gapped stock plugs...
My two cents.
- 41
October 27th, 2002 04:26 AM #8Ignition wires do increase their resistance with age so replacing them will improve performance. Performance aftermarket wires will yield very little if none performance gains if you have a realtively stock engine. Just get the stock or OEM wires and save your money. Check your spark plugs also while you're at it. :mrgreen:
- 197
October 27th, 2002 11:21 AM #9If you MUST repalce the wires, only 2 brands works and last. NGK wires and Magnecor.
October 28th, 2002 11:02 AM #10
Thanks for the info guys.....I'm currently using Bosch Super 4 spark plugs.......and stock wires and ignition........it's running superbly well naman.......I'll take your advice on this.....save my money na lang........:D
Daming issue ng SU7:grin:
Xiaomi E-Car
