Help naman,
Nawala kc busina ko nung pinaltan ko yung manibela ko eh!
First humina yung busina, tapos totaly di na gumana nung nakabit ko na yung wheel.Dalawang wire lang naman ang naka kabit dun,yung graoung at yung naka recta and i've double check and install it again as is, but tolaly nawala na.Meron bang fuse yun or wat ever?
baka busted fuse... check your fusebox nakalagay dun kung san ang fuse para sa busina... then double check your wirings again baka loose connection lang
parang may thread tayo ganito ang title ,
tapos may sumagot na "Baka Ninakaw" hehehe
since nag palit ka ng steering wheel ,
check mo ang wiring connection mo baka may nag loose ,
or iyon metal plate sometimes like rod or pin na my spring
na lagi nakadikit sa act as a ground sa steering column
check mo din also ang Fuse ,like what bro gwapito sez
