Page 1 of 2 12 LastLast
Results 1 to 20 of 23
    Oct 2005
    guys, tulong naman. i have this 7 months old car na ayaw magstart. we found out that the battery electrolyte was very low. so i sent this battery to a nearby battery shop for electrolyte top up and recharging. i have just recently sent this car for a periodic maintenance on the casa two weeks ago. i read their brochure and part of this maintnenance checkup is to "check/top up battery electrolyte level and terminals for loose connection/corrosion; check battery clamp".
    so i presumed that they overlooked this procedure during the periodic maintenance service. so, what action can i take. i dont mean any lawsuit or something, i just want to know if i can ask them for a replacement battery or do i need to send the car for check up again.
    Sep 2005
    sana sa casa mo inereklamo baka underwarranty pa ang battery. afaik, the battery has its own warranty independent from the car manufacturer. Thru casa nalang kung within the warranty period pa car mo.
    hi everybody, i have here a "Revive" battery electrolyte that will help solve your battery problems. This is a battery life extender and conditioner. It helps break down deadly lead sufation forming on plates, and restoring normal charging action in battery cells. Try it!
    that happened to our car too. since the "dead batt" luckily occured near the casa, we brought it there, told the people there what happened and they replaced it w/ a new one. wala naman siningil sa amin. btw the car was w/ us for about 10 months already
    Apr 2006
    Quote Originally Posted by alsosing
    Alsosing, can you share a little bit more on your "Revive"? How do much do you put in the battery (assume MF) and when is it ideal to be put in? How much is the product and in what quantity? Any testimonials to share?
    Quote Originally Posted by easydeal
    Revive is like a vaccine (preventive maintenance) to your battery wherein it prevents and/or it breaks down deadly lead sulfation forming on the battery plates (lead sulfation is another cause of premature battery failure). It is used as a substitute of distilled water. Pag nababawasan electrolyte mo, instead of adding distilled water, u can use this. Yung distilled kc 100degC and boiling this, this revive is 140degC. It helps prolong battery life span. pag MF gamit mo, mahirap lagyan kc u have to break the warranty seal...you can try it pag beyond warranty na yung MF mo... P180 per 850ml bot yun.
    Feb 2005
    san nabibili to brader?
    Quote Originally Posted by box_type
    bago plang e2 d2 sa pinas, d pa masyadong kilala but tested. Nasa mandaluyong ang distributor. Interrevive Phils, Co.
    Apr 2006
    Alsosing, you got me convinced. Where can I buy it?
    Dec 2003
    dapat papaplitan mo sa casa ng maintenace free battery... undrer warranty namn..
    Oct 2005
    ok thanks guys baka kasi sabihin ng casa void ang warranty kasi pinagawa ko sa iba eh. or baka sabihin ok naman ang battery at walang problema. so baka hindi nila palitan. kasi nga natop up na ang electrolyte at naparecharge ko na. ang sa akin lang naman ay part of the maintenance procedure nila yune eh. bakit naoverlook.
    Mar 2005
    7 mos? 10 mos? dead battery? wtf? ang bilis ah... di ba MF battery stocks ng bagong kotse ngayon?
    May 2005
    what is your car? ganyan din ang nangyari sakin pinalitan din walang bayad..
    Oct 2005
    hindi maintenance free ang stock na battery eh. better replace with this. cvt kasi kotse ko.
    Oct 2003
    beachbum, anong car mo? lancer or honda? sa amin kasi on both hondas maintenance free na yung battery. pero accdg to some users, pag malapit nang mag 1 year yung car, pumapalya na yung battery. redeemable naman yung warranty on the battery...hassle nga lang..
    OT pero suggestion lang, kung may plano kayo bumili bago, try using NAPA batteries. doble ng price ng motolite pero 65 months warranty sya. sa pa-64th month bumigay, papalitan nila ng bago.
    Oct 2005
    by the way, lancer ang car ko 7 months old
    Sep 2005
    Quote Originally Posted by aceshark
    Bka naman di lang 2SM yan? eh sa City 1SM lang kasya kahit gustohin mo ipagkasya ung 2SM tulad ng Vios e di kasya huhuhuhu...
    baket nga pala a lot of new local cars dont come with MF battery...
    Jan 2003
    ...san nakakabili nung mga OPTIMA batteries?
Battery warranty on new cars
