tsikoters, park light indicator light up on dash board even if the park brake is release, pls help...on my kia pregiothanks...
sir parang grounded yung lights... try to check the grounding of the car.
1st thing is check your brake fluid level. Low fluid makes that thing light up. If low just top up and the light should go out.
Ground is also possible. If both brake fluid and ground is ok, have your brakes checked and serviced.
It means you have a problem w/ your brake system. Like "userfriendly" said most likely it is low on fluid, check fluid and fill as needed. Brake fluid is enclosed it doesnt need periodic filling, there is a problem it could be anywhere. Check the Master cylinder, caliper, wheel cylinder or a rotting brake line. Flushed your brake system every 50,000 kilometer so moisture dont rot the brake line.
this maybe out of the topic pero ask ko lang po kung masama po ba na hinahayaang walang naka lagay na parklight bulbs sa headlights leaving it empty.?
mga bro okay naman po ang level ng fluid sa reservoir ng brake, di po kaya may problema ang mechanical ng hand brake lever switch.......thanks for input
stryke wiring lang po electrical ganyan din yung sa pregio namin dati nakalimutan ko lang kung anu ginawanung electricians
teka, ang pagkakabasa at pagkakaintindi ko sa problem ay parklight not the break light and afaik walang kinalaman ang fluid level kung ayaw magswitch off ang parklight ng pregio niya. anyway going back to the problem have you check the switch stick ng parklight mo sa may steering wheel? most probably loose contact kaya ayaw magswitch off.
kung ok ang brake fluid level, pa check mo baka stuck an park/hand brake ng pregio mo. Nangyari sakin dati, nagstuck isang gulong, pero di umilaw, nalaman ko na lang nang nasunog/overheat ang brakes ko.
I think the switch on the hand brake lever is having a problem with contact, na solve na din po thanks to all...
