Results 1 to 10 of 11
- Feb 2008
- 577
July 8th, 2008 07:36 AM #1hi,
how do you remove the oxidation in the distributor cap contacts? hindi naman grabe ang pag-aasin (namumuti) ng points, pero i wanted it gone. i dont have cracks in the cap. i just wanted the oxidation removed.
is there a way to remove this besides sandpaper method?
July 8th, 2008 08:01 AM #2
after sanding spray it with WD-40. excellent as well in battery terminals. it's a pretty good insulator.
- Feb 2008
- 577
July 8th, 2008 01:10 PM #4
after spraying WD-40 di na babalik yan.
here are some about WD-40.
What does WD-40 do?
WD-40 fulfills five basic functions:
1. CLEANS: WD-40 gets under dirt, grime and grease to clean. It also dissolves adhesives, allowing easy removal of labels, tape and excess bonding material.
2. DISPLACES MOISTURE: Because WD-40 displaces moisture, it quickly dries out electrical systems to eliminate moisture-induced short circuits.
3. PENETRATES: WD-40 loosens rust-to-metal bonds and frees stuck, frozen or rusted metal parts.
4. LUBRICATES: WD-40's lubricating ingredients are widely dispersed and tenaciously held to all moving parts.
5. PROTECTS: WD-40 protects metal surfaces with corrosion-resistant ingredients to shield against moisture and other corrosive elements.
http://www.wd40.com/faqs/Last edited by XTO; July 8th, 2008 at 01:15 PM.
July 8th, 2008 01:33 PM #5
Haven't tried to use WD40 on it. However, normally, I use very fine sandpaper on it. Afterwhich, I wipe/clean with dry cloth....
Kung emergency minsan at walang sandpaper,- you can scrape the oxidation off using a flat screwdriver.....
6404:pump:
- Feb 2008
- 577
July 8th, 2008 01:51 PM #6i used wd 40, but still, the white corrosion is still present. matigas parin
July 8th, 2008 02:39 PM #7
Replacement / transparent ba distributor cap mo? or still the OEM? Based on my experiences back days, replacement distributor caps (clear / transparent) contacts tend to corrode faster than the OEM (colored red orange). it’s because the contacts are made of copper whereas those from replacements were made of steel. Madali siyang magputi-puti parang kup*1.
Sikwat style done by manong mechanics will remove the rust build up temporarily but masyadong matalim ang screwdriver, nauuka yung contacts. IMO fine sandpaper ang solusyon + WD-40. even sa coil, spark plugs okay ito.
my 1 cent.
- Feb 2008
- 577
July 8th, 2008 02:52 PM #8contactless ang distributor ko. pickup coil ang ginagamit. ang ignition coil, built in sa loob ng assembly. mitsubishi cei type. my cap is still the original which came from the factory 8 years ago.
THE AUTO SPECIALIST
- Mar 2006
- 607
September 13th, 2017 06:18 AM #10
Just to revive this thread because of the weather higher probability of corrosions, Brought the truck to Reys cubao yesterday braving typhoon Maring, changed battery clamp put a jacket in the positive some wires and added some grease. So far so good.
Xiaomi E-Car
