Ano kaya prob nito mga gurus
Mahina yung ilaw ng oil warning
With light
No light
Car is 2010 everest.
Patulong naman po.
#Retzing
With light
No light
Patulong naman po.
#Retzing
generic explanation:
oil pressure is dependent on three things:
1. oil volume in the sump;
2. oil pump; and
3. resistance to oil flow.
you may be low on oil. it's easy to check this.
is your oil pump ok? this, i know not how to check.
your crankshaft bearings are so worn out, they offer little resistance to oil flow. this results in low oil pressure being generated. the oil light (in my experience) lights up but it tends to flicker.. translation: engine overhaul.
ung ilaw ng oil pressure lang ata tinutukoy ni sir beni na mahina pagka start ng engine hindi ung lumalabas na oil pressure warning light pag tumatakbo na.
Kung walang check engine, ok yan. Basta tumatakbo na at walang ilaw, no problem. Kung umilaw, low on oil. Check dipstick to make sure.
May loose connection lang siguro sa supply ng battery terminal , ignition switch contact at fuse.
Parang walang ilaw. Yung aninag ng ilaw sa madilim galing sa adjacent lighted peanut bulbs, Iilaw dapat yan when engine not running. Kung under 3yr warranty, claim mo na lang sa dealer. Pacheck mo ang pressure switch baka stucked or busted peanut bulb.
Oil sensor problem. Nakuha sa change oil. Umiilaw na ngayon. Pinacheck ko yung gauge kanina sa may J6 along kaliraya street ok lahat ng leds. Hehe
Out of warranty na siya. Til july lang warranty.
#Retzing
