Results 1 to 9 of 9
    Jun 2005
    hi,
    i found some apps on the android market that supposedly provides engine information. would anyone know how it can be used?
    wala kasi ako yung connector para sa OBD2 port. baka may alam san nakakabili nito?
    Sep 2004
    Havent seen that app pero baka this would help... i saw an OBD to bluetooth interface sa sulit. Just plug it in sa OBD port and pwede mo na connect android mo via bluetooth. Search mo lang OBD bluetooth
    Jun 2005
    thanks! may nakasubok na kaya nito?
    Actually im more after getting the coolant temperature followed by getting fault codes later on. idiot lights lang kasi ang sa kotse ko eh
    Jun 2005
    Quote Originally Posted by kinyo View Post
    nice! yan din balak ko gawin eh. accurate ba? torque din app mo?
    yup Torque Pro gamit ko ... it is highly customizable so accuracy depends on your setup ... if you enter vehicle data/parameters correctly, then its output are accurate
    you can actually make your own formula or tweak the built-in formulas to improve accuracy
    but bear in mind, Torque is just a hobbyist app ... it is still evolving ... compatibilty is not guaranteed, i.e., some sensors may not be accessible due to proprietary ek-ek ... still, the app can access lots of sensors that makes it worth having!
    check out Torque's forum ... you'll learn a lot
    Torque Discussion
    i have this also, got the unit from dx. using torque. very useful for long drive. Problem is BT version cant be used on ios, if not JB'd. very useful pang monitor, ng status ng engine, even yung FC, meron din. i'd say sulit ito, even bihira ko na sya magamit, dahil i've switch mobile phone to ios. nakikihiram na lang ang ng android sa wife pag need ko i plug itong scanner.
    Jun 2009
    You also need a vehicle software to operate the OBD2 scanner even you have the 16 pin plug.
    Jun 2005
    Quote Originally Posted by nickriingen View Post
    i think thats the whole discussion hehehe.
    the app(torque) is the software that operates the plug
OBD scanner for android
