Results 1 to 6 of 6
    Sep 2008
    Hi mga sirs,
    Bago lang pinalitan ang both rear tail lights ko since nabasag ung left side. Dual-filament ang bulb since share ang tail light and brake light. Here is my problem.
    If "on" ang light, left side is lighted up but right side is not, or off siya.
    If "on" and light and brake is pressed, left side brake light doesn't work, although lighted siya but hindi super bright na light if nka brake ako. This time, the right side works.
    Not sure if busted ang both bulbs, either of the filament sira sa both. Any advice will be appreciated. Tia!
    Jun 2011
    Naku medyo magulo. Bring it to a good mechanic/electrician. Kayang kaya ng test light yan.
    Feb 2009
    Quote Originally Posted by poldo0808 View Post
    Hi mga sirs,
    check the way the light bulbs were installed. although they are idiot proof installation, there is no guarantee if it was installed by a novice. the 1157 light bulb if it is what you are using, has two lugs of different depths into the light socket, it might have been inadvertently installed backwards
    Sep 2008
    will do sirs. i'll see if i can check/fix this myself. if not, dalhin ko na lang ulit sa shop na nagpalit sa tail lights pra sila nalang ang mag figure out sa problem and fix it.
    Sep 2004
    Hi mga sirs,
    ginalaw ba ang wiring connections? sa tingin ko ginalaw yan kaya ganyan.
    Apr 2011
    Hi mga sirs,
    I think both your bulbs have melted terminals. Try replacing the bulbs sir.
Nissan Sentra 2005 Brakelight/Tail light problem
