i'm having great difficulties starting my mazda 626. i noticed that after a night in the garage, my battery voltage is very low, 10.6 volts. this is the voltage of a fully-discharged battery, according to things i've read.
once the car has started, voltage across the posts is about 13.8 volts. i am concerned that this is a bit too low -- things i've read say it should be 14 volts. also, when idling, full aircon, full headlights, and stereo, the stereo drops out periodically (namamatay-matay). and the voltage across the posts drops to 12.5 volts or thereabouts.
i left the battery disconnected for a night, and its voltage went down from 12.65 volts to 10.6 volts, so it seems the battery cannot hold a charge anymore. however, i don't want to replace it right away because i think the alternator is not charging it fully, and a new battery might just get damaged after a month or two (the fact my stereo drops out means not enough juice is getting to it).
is there a way to adjust the regulator? maybe it is not providing enough field voltage to the alternator, so the alternator can't keep the voltage up at 14 volts. or could it be, the battery is so weak that the alternator's output is affected?
p.s. i have verified that the battery is not discharging overnight through some short or something (i put an ammeter in series with the battery), so it's not some dumb thing like the trunk light or dome light being stuck on..
