Results 1 to 7 of 7
    guys, need help. namamatayan ako ng makina kapag nakastop un sasakyan. engine idling slowly drops hanggang sa ma-off ung engine. san kaya ang problema neto? tnx a lot guys!
    Sir ano oto mo?. Usual culprit is the throttle body. It probably needs cleaning sama mo na din yung IACV. Ganyan din yung sa akin. After cleaning these two ok na sya. Nga lang it took two tries kasi yung unang naglinis sablay ang gawa kaya dapat maayos na mechanic althought some DIY lang. Hope this helps.
    tama si pol3.. and yung mga sensors pa linis nyo na rin (MAF)... aac/iacv/throttle body cleaning.. sakin naayos ng speedyfix yung idling issue ko na hindi naayos ng casa.. nilinis lang yung mga yan...
    Carburated or EFI?
    Jan 2009
    nalubog ba yan? ako kasi nalubog, then narevive na. a few days into running, i had the same problem: namamatay pag idling. may revolution pag iniistart, pero hindi kumakagat. what they did was drain the fuel: apparently, may tubig pa pala sa fuel tank, so probly damay ang fuel pump and/or fuel filter. after that, hindi na namatay (so far!). hehe just sharing.
    Thanks sa mga nagreply. my ride is KIA GTX '97. di nmn sya nalubog. ngpadrain ako dati nwala un tirik. pero lately lng eh bumalik n nmn. I noticed na mejo nagooverflow un sa carb eh. how do i deal with that?
    Well thats your problem, the overflowing of fuel causes un balance fuel and air mixture. The fuel overflow is a cause of misadjusted carburator float or a needle valve stuck open.
namamatayan ng makina during idling
